If I lower the compression, do i get less vacuum?
Old Aug 13, 2007 | 08:45 AM
MidwestAutoWorks's Avatar
Default If I lower the compression, do i get less vacuum?
Lowered the compression from 11-1 to 9-1
Before I had 18 on the vacuum side, now i only get around 11-12, my car is surging, or hunting when started and I can not find a vacuum leak anywhere.
Old Aug 13, 2007 | 08:55 AM
miyagi's Avatar
Default Re: If I lower the compression, do i get less vacuum? (MidwestAutoWorks)
i'm roughly 9:1 and get 20 in/hg at idle ... and i did when i was 9.5:1, 10:1, and ~11:1
should pull the same vacuum, or at least damn close regardless of your compression.
I do remember that when i went from 11:1 to my current motor, the car surged and had 10 in/hg of vacuum ... messed with the map a bit and vacuum was fine.
Old Aug 13, 2007 | 09:03 AM
Default Re: If I lower the compression, do i get less vacuum? (miyagi)
I wonder if its my MAP then, I installed a new TB and had to clock the TPS a few degrees and then go into the ems and make up for the difference in voltages
Old Aug 13, 2007 | 10:38 AM
blaze the chemi's Avatar
That could be it with the MAP. Also if one of your cylinders are not firing, this would cause less vacuum.
But since your motor is searching, loping, not idleing smoothly, then I guess a sensor is whack or there is a leak somewhere. G/L
stevenDAtegra
Jul 14, 2009 08:26 PM
my_slow_civic
Sep 28, 2008 07:50 AM
KeyserSoze
Oct 20, 2005 08:36 PM
NotPhilTran
Mar 17, 2005 05:40 AM
dustin
Oct 1, 2004 01:41 PM
