gsr-t underboosting.. why please help
Old Aug 17, 2007 | 04:30 PM
boostedgsr1234's Avatar
Default gsr-t underboosting.. why please help
hey guys iv got a built b18c with a turbo and had it tuned at 18 psi.iv been driving it for a while now with no problems and now all of the sudden its only pushing 15 psi . iv already done a leak down test on the whole turbo system and couldnt find any leaks i have a turboxs b.c. btw any help would be grreat
Old Aug 17, 2007 | 04:36 PM
Schister66's Avatar
Man U FTW
did the boost controller get bumped??
Old Aug 18, 2007 | 06:20 AM
Default Re: (Schister66)
not that i know of do you think i should buy another one? is there anything else that may cause this?
its really weird, it went from what i had it set at (18 psi) then to 15psi, then 10 psi now its back to 15 wtf
Old Aug 18, 2007 | 06:27 AM
TinyTitan's Avatar
Default Re: (boostedgsr1234)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedgsr1234 &raquo;</TD></TR><TR><TD CLASS="quote">not that i know of do you think i should buy another one? is there anything else that may cause this?
its really weird, it went from what i had it set at (18 psi) then to 15psi, then 10 psi now its back to 15 wtf</TD></TR></TABLE>
sounds like the boost controller is acting up....
Old Aug 20, 2007 | 12:19 PM
Default Re: gsr-t underboosting.. why please help (boostedgsr1234)
iv done another leak down and everything from the turbo to the intake mani. gasket is air tight. is it a common problem for the turboxs b.c. to go after a while
i cant think of a reason why all the sudden the boost is 3 psi lower then i had it set at any reason why i shoulnt turnit up? what else should i look for?
Old Aug 20, 2007 | 01:24 PM
morgan@synapse motorsport's Avatar
take the boost controller out of the equation and see if boost is holding steady.
Old Aug 20, 2007 | 01:33 PM
rdssk8rcs1's Avatar
Default Re: (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">take the boost controller out of the equation and see if boost is holding steady.</TD></TR></TABLE>
Yes. Also what is your wastegate spring rated at?
Old Aug 20, 2007 | 03:46 PM
Default Re: (rdssk8rcs1)
10 psi spring and how does taking the b.c. out work iv never done it? i just take it out and connect the hose directly to the w.g. what should it read?
Old Aug 21, 2007 | 03:08 AM
bump
Old Aug 21, 2007 | 08:25 AM
HiProfile's Avatar
One side of the boost controller goes to the wastegate, the other side to the turbo housing OR intake manifold. You should really read up on how a boost controller works - you simply replace it with a coupler for the 2 lines it attaches to, and you are back to the WG's 10psi spring. If it can't hold 10psi, its most likely not your turboxs boost controller.
Old Aug 21, 2007 | 06:00 PM
Default Re: gsr-t underboosting.. why please help (HiProfile)
ill try that thanks alot guys ill let u know how it goes
slow93eg
Dec 6, 2006 12:58 PM
j87w
Feb 14, 2006 09:07 PM
Boostin Ex
Dec 17, 2004 01:20 PM
booscivic
Jun 25, 2004 01:10 AM
yellowturbo
Oct 8, 2003 09:29 PM
