2 step or 3 step colder plugs?
Old Aug 14, 2007 | 06:05 PM
94c1v1cex's Avatar
Default 2 step or 3 step colder plugs?
got a hmt setup i'm about to install on my d15b should i use 2 step or 3 step colder plugs for my setup?
14b turbo... probably not more than ~13 psi
Old Aug 14, 2007 | 06:11 PM
juice91si's Avatar
Default Re: 2 step or 3 step colder plugs? (94c1v1cex)
i think its one step colder for every 100 extra hp you make.
i think.. maybe someone can confirm..
Old Aug 14, 2007 | 06:14 PM
1cpu's Avatar
Default Re: 2 step or 3 step colder plugs? (juice91si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juice91si &raquo;</TD></TR><TR><TD CLASS="quote">i think its one step colder for every 100 extra hp you make.
i think.. maybe someone can confirm..</TD></TR></TABLE>
thats what i have been informed aswell....
Old Aug 14, 2007 | 07:07 PM
94c1v1cex's Avatar
so if i'm only gonna make ~200 whp then i could go 2 step colder just to be safe?
Old Aug 14, 2007 | 07:11 PM
juice91si's Avatar
no, go one step.
tony413's Avatar
general rule of thumb
5psi stock
5-10psi one range colder
10-15psi two ranges colder
15-up psi three ranges or more colder than stock
Old Aug 14, 2007 | 07:12 PM
juice91si's Avatar
ngk: bkr7e
Old Aug 14, 2007 | 07:42 PM
94c1v1cex's Avatar
Default Re: (tony413)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">general rule of thumb
5psi stock
15-up psi three ranges or more colder than stock</TD></TR></TABLE>
see my problem is that i'll be running anywhere from 8-13 psi probably... so wdf??? 1 step or 2 step?? i can get 2 step colder for really cheap
Old Aug 14, 2007 | 08:06 PM
tony413's Avatar
Default Re: (94c1v1cex)
be safe an go with the two step
Old Aug 14, 2007 | 08:25 PM
94c1v1cex's Avatar
part number anybody?
Old Aug 14, 2007 | 08:35 PM
cbustuner's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juice91si &raquo;</TD></TR><TR><TD CLASS="quote">ngk: bkr7e </TD></TR></TABLE>
Old Aug 14, 2007 | 08:37 PM
94c1v1cex's Avatar
Default Re: 2 step or 3 step colder plugs? (cbustuner)
i've also heard about bkr7e-11 what is this?
Old Aug 14, 2007 | 08:40 PM
cbustuner's Avatar
ones pregapped ones not or so I heard,just run what i quoted im using those in my turbo z6 now
edit
quoted from 1992si on d-series.org
''Go to the auto parts store that carry's NGK. Order NGK p/n 6097. That is the BRK7E. It is two step's colder. I keep the p/n here next to my PC. Don't use any other NGK plug unless you want there race plug.
Those of us that know have called NGK (it's free) and ask one of the Tech's. They will tell you more then you had any idea they knew. Use the BKR7E it comes gapped at .028 the BKR7E-11 comes gapped at .041 or 11mm.''
They should cost you about $2.00 each.
http://www.ngk.com/
go to the FAQ.
original thread
http://www.d-series.org/forums...plugs
Modified by cbustuner at 5:54 AM 8/15/2007
Old Aug 14, 2007 | 09:48 PM
94c1v1cex's Avatar
Default Re: (cbustuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cbustuner &raquo;</TD></TR><TR><TD CLASS="quote">ones pregapped ones not or so I heard,just run what i quoted im using those in my turbo z6 now
edit
http://www.ngk.com/
go to the FAQ.
original thread
Modified by cbustuner at 5:54 AM 8/15/2007</TD></TR></TABLE>
thanks man! that's exactly what i was lookin for
looks like it's bkr7e's for me
u n v kenny
Aug 20, 2007 11:54 AM
Boostage
Jul 28, 2006 08:34 PM
Ultra Jurassic
Apr 21, 2005 07:35 AM
Kwuaymaikrup
Feb 11, 2004 08:25 PM
Vtec92Civic
Aug 23, 2003 07:00 AM
