PLX wideband not reading
I just got my wideband all in and set up, it's not reading anything only saying rch with the 10 on the side, same thing it did before I hooked up my o2 sensor. Anyone have any ideas whats wrong? PLX SM-AFR.
Anyone? I'm fairly perplexed at this one. It's all hooked in and working well(outside of the sensor I suppose. I did cut the harness that plugs into the box to get it through the fire wall but I marked it and put them back together accordingly...no lose connections or anything at all.
Thats what I thought but theres only 6 wires, the only ones that could be are the two white ones, but I marked it and simply put them both together. I'll double check though!
Re: PLX wideband not reading (96vtecI4)
are you using DM-5 for display? if you got the whole kit, then nothing needs to be put together as far as sensor goes.. for dm5 for plain reading you just need to connect to either tx or rx and have power wire from 4 wire plug
check your manual, wiring up wrong will damage it. make sure you solder the main power/ground wire - i have no idea why they couldn't provide one already assembled
Yeah, I changed all the wires around that I could(the installer put the gnd in the analog so I changed in to wideband and then the lambda) he also pluged both RX and TX in, I unplugged and plugged in both with each setting and the guage switched between saying RCH and just flashing the 10 on the side. Any other ideas? I dunno wtf is going on.
Never mind guys I got it figured out....he had the RX and TX both plugged in and backwards. Do everything yourself lol.
Modified by 96vtecI4 at 2:02 PM 8/12/2007
