Hush Performance Clutch Master Cylinder Line
Last night, I installed a Hush Performance clutch master cylinder bracket and the willwood master cylinder that they offer. After bleeding, the pedal was very hard and after something like an hour of driving, I needed to make a clutch adjustment, so I checked for leaks and found none, made a small adjustment to the push rod, and headed back out. Almost immediately I was not getting full disengagement again. This time when I looked at my adjustment, the push rod was very crooked and the pedal itself was bent. I am imagining that the reason for the super stiff pedal and thus bend pedal is the size of the line I used...maybe?
I used a -3an stainless braided line from a banjo on the master all the way to the slave, about six feet long.
What lines have you guys used? Has anyone else had a similar issue?
Steve at Heart
Re: Hush Performance Clutch Master Cylinder Line
@Bently_Coop ? Aren't you using HP stuff?
OP contact Hush directly, I'm sure Robert will get you squared away.
rhdins
11-03-2009 03:22 AM
