D15b2 timing problems
Re: D15b2 timing problems
The pring behind the belt popped off the upper hook.
found a loose spring on my tensioner behind the timing belt there.
I think this is my problem... that cam key doesn't look right..
Wire config
Tdc
Pointed at no 2
This doesn't look right to me?
Wire config
Tdc
Pointed at no 2
Yea I already had the crank pulley off and that one was in. When I took the cam gear bolt off I noticed that the key way on the cam gear wasn't right below the dot so I pulled it off and the keyway is sheared in half and it welded the other half in the cam gear. What would cause the pin to shear like that? I bought this car from some random guy who did shitty work.. missing nits and bolts everywhere..
the cam bolt being loose would make this happen
but now we know the problem ^_^
im sure once you get the parts replaced the car should start right up
your timing will finely be good to go
tricura
211
09-30-2009 08:52 AM
