Dpfi to mpfi no power to injectors
I have a d15b that was originally dual point. I swapped it to multi point but i have no power to the injectors. I used a test light and checked all 4 injector clips and no power to them. This is my first dpfi to mpfi swap so any help or tips to check would be greatly appreciated
Re: Dpfi to mpfi no power to injectors
What walk through did you follow? What parts did you use? Did you keep the resistor box? Can't tell you anything if we don't know what you did...?
I spent all night looking at forums and diagrams and the pinouts for the ecu and traced back all my wires and found out that i wired a15 from the resistor box to a17. Checked it out and had power to the injectors and started first try. Thank you for the response though ,greatly appreciated. Hopefully this helps someone.
crxcess
10
05-26-2006 09:56 AM
RTW DC2R
04-05-2006 08:12 AM
