WHAT INJECTOR'S ARE BEST?
Old May 20, 2005 | 01:56 PM
darkblue1998ls's Avatar
Default WHAT INJECTOR'S ARE BEST?
I have a 98 integra ls and I am going to put a jackson racing super charger on it.(I know I know turbo turbo turbo the ls but no! so please no comment on why not turbo.)I am just trying to find out what type of injectors do I have now and what would be a good replacement once I boost?I have heard alot about the dsm eclipse injectors but also heard you have to wire up some resistor box or something.I really would like good performance but just straight swap out.Thanks!
Old May 20, 2005 | 02:02 PM
s2kdre's Avatar
Default Re: WHAT INJECTOR'S ARE BEST? (darkblue1998ls)
no matter what you're gonna have to use obd1 clips, all injectors are the same quality and around the same price.
Old May 20, 2005 | 02:24 PM
Default Re: WHAT INJECTOR'S ARE BEST? (jdmhonda)
Isnt there an after market company like RC or something that just makes replacement injectors that are just larger.I dont know anything about fuel injectors like saturated non saturated 440 750 all that is blah blah blah to me.I just would like some kind of explination on what type my stock ones are and what do they flow and were can I find better ones for when I boost.
Old May 20, 2005 | 02:26 PM
Ben Huynh's Avatar
Your stock injectors are staurated and push 240cc. You want to replace them with larger staurated injectors. Since you're OBD-2, you'll need the wire clips.
Old May 20, 2005 | 02:30 PM
HitEm'Up's Avatar
Go with like a RC 440 would be fine
Old May 20, 2005 | 02:33 PM
EnzoSpeed's Avatar
Default Re: WHAT INJECTOR'S ARE BEST? (HitEm'Up)
Just get the DSM 450's for $50 and wire in the resistor box. Compared to installing one of those nightmarish JRSC units, the resistor box is a walk in the park.
Old May 20, 2005 | 02:50 PM
Default Re: WHAT INJECTOR'S ARE BEST? (ben@importparts.com)
What do you mean by the wire clips? I dont have them on the stock injectors?
Old May 20, 2005 | 02:55 PM
Ben Huynh's Avatar
You have OBD-2 clips now. Most if not all performance injectors use OBD-1 clips so you'll need order clips with your injectors.
Old May 20, 2005 | 02:57 PM
BodyKits NW's Avatar
Yah most do run OBD-1 clips. If you really wanna get the most affordable then pick up some DSM 450's. Like already stated, they can be had for cheap.
If you plan on getting a injector larger than 450's then go with Precision. They are Hands down the best injector for the money.
Old May 20, 2005 | 03:00 PM
Thanks for the info.What injector should I go with and what brand do you think would be the best?Were is a good place to get them also?
Old May 20, 2005 | 03:01 PM
Ben Huynh's Avatar
Default Re: WHAT INJECTOR'S ARE BEST? (BodyKits NW)
I don't know why you guys are recommending peak and hold injectors to him. His knowledge about injectors is limited. I say go with staurated injectors because they offer a no brainer install.
Old May 20, 2005 | 04:46 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkblue1998ls &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info.What injector should I go with and what brand do you think would be the best?Were is a good place to get them also?</TD></TR></TABLE>
Everyone reccomends DSM 450s. Get them on ebay for $50. Then get OBD-1 injector clips on ebay for $5. Then get a resistor box on ebay for $10.
I installed everything according to one of the write-ups here in the honda-tech archives.
kidd_drastic
Jan 12, 2006 02:18 PM
dominate9
May 16, 2005 05:38 AM
pissedoffsol
Nov 21, 2003 11:46 AM
simple4012
Sep 3, 2002 07:11 PM
