greddy profec bspec2 wiring
Old May 22, 2005 | 11:18 PM
DOHCtah's Avatar
Default greddy profec bspec2 wiring
hey guys,
I recently bough a used Greddy profec B spec 2.. but one of the wiring harnesses that plugs into the command unit had the wires ripped out.. the one with the green and white wires that goes to the solenoid.
does anyone know whether the green/white goes right/left?
looking at the rear of the control unit, starting from the left to right it goes:
red, black, vacuum port, (???), (???), aux switching.
the (???) is where either the green or white wires shoudl go. Could someone check this for me real quick? thanks
Old May 23, 2005 | 10:51 AM
DOHCtah's Avatar
Default Re: greddy profec bspec2 wiring (DOHCtah)
bump
Old May 23, 2005 | 01:23 PM
DOHCtah's Avatar
upp
Old May 23, 2005 | 02:19 PM
Boosted2K1Civic17
Should be, red to power, black to ground. The vac input you tap into the vacuum pressure hose (Where you hook up a boost gauge). get a t-fitting that has at least 2 outputs (for however many things you need to tap into that line for to get a reading (eManage/ems/afc, boost gauge, boost controller) Dont cut it in another spot. Just use the same spot you tapped already.
You should also have an in and out. I believe in is from the turbo to the in, and out is from the out to the wastegate. In should be pressure coming from the turbo and out opens the wastegate when it sees the set boost.
I could be wrong on ths in/out, but I hope this helps.
Peace
Old May 23, 2005 | 05:03 PM
DOHCtah's Avatar
Default Re: (Boosted2K1Civic17")
hey thanks for the response but your answer not even close to what i was asking.. lol
I know where the wires go to for the install.. its just the 2-wire green/white harness that plugs into the profec command unit had the wires ripped out of the harness when I bought it and I dont know if green or white is on the left or right side..
again.. from left to right looking at the back of the unit..
red, black, vacuum, (???), (???). aux.
I need to know which (???) is green or white. thanks.
JDMCRX
Jul 27, 2014 05:45 AM
Turbo_Mike
Jun 4, 2005 04:55 PM
Bloodline
Nov 15, 2003 09:30 PM
DeezNutts
Sep 2, 2003 09:31 PM
shadowdawn
Apr 2, 2002 12:49 PM
