######injector question for those of you using dsm injectors#####
I recently picked up a set of 450cc dsm injectors for my turbo project. A friend of mine told me 450's were too much for my d15b vtec with 14b turbo setup. but i have a afc hack so i coul decrease the fuel if needed right? He was telling em a friend of his had the same injectors and the ecu couldnt handle all the fuel so it would cut off. What should i do? is he right?
Re: ######injector question for those of you using dsm injectors##### (slotec)
smack your friend please. Sure they will work with the hack or anyother type of fuel management. Maybe he was talking about to much fuel if your using a fmu?
But the 450's are a great and cheap way for larger injectors
Re: ######injector question for those of you using dsm injectors##### (Curtis2kul)
yea im getting those a walbro 255 fuel pump, some type of rising fpr(fuel press reg)like a 10:1 or a 12:1,and eventually a plx m300 wideband.
dude, dsm 450's with the afc hack is probably one of the most common fueling setups for turbo hondas ever
your friend apparently likes make assumptions with no basis on reality
Re: (Bseriescivic5)
If you want to spend the $$ on a wideband, get rid of the AFC and get a shcoeted ECU and run Crome or Uberdata on it. Just get rid of the damn AFC hack though!!!
Re: (nfn15037)
The hack is fine for 7PSI and under applications. You won't need an FMU for it...or what you callinga rising fuel pressure regualtor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bseriescivic5 »</TD></TR><TR><TD CLASS="quote">DSM s work with B-series too correct? im pretty sure they do, jsut need varification.</TD></TR></TABLE>
Yep, I run them on my b-18b. You need a resistor box for it though
Re: (adseguy)
uh oh resistor box. where do i find this so called resistor box and off what car? Also do the fuel injector clips suppose to connect to the 450cc dsm;s cause i tried on a harness and it didnt clip.
hysteria411
Engine Management and Tuning
26
09-30-2013 06:12 PM
threatcon13
01-31-2002 08:32 AM
