TIMING ON BOOSTING CAR
Old May 21, 2005 | 01:27 AM
all_out_jdm's Avatar
Default TIMING ON BOOSTING CAR
hey im about to boost my b16 but how much degrees should i retard it...i think i might boost 7 psi or 10 so let me know..thanks
Old May 21, 2005 | 01:57 AM
Default Re: TIMING ON BOOSTING CAR (student_n1)
Old May 21, 2005 | 02:50 AM
Sifu's Avatar
This is a question I would like to ask aswell as I will be piecing together my own turbo kit soon as well as tuning it myself. The amount of "timing" depends on your exhaust gas temp. right? I mean if you want to know what it should be set at you need a EGT gauge right?
Old May 21, 2005 | 04:23 AM
tilt's Avatar
rule of thumb is about 0.9 - 1.0 degrees of retard per psi for a conservative basemap. You can then adjust it accordingly when you get it tuned -- .75 per psi is probably a good goal, just keep in mind every engine is different.
Another method is to step-retard, which is much better for the non-boost/low boost maps imo. If you are going to see dyno tuning, prob the ideal thing would be to find your maximum brake torque on the dyno then back off the timing a bit.
Just do a search and you will see plenty of info.
ghost14
Engine Management and Tuning
Sep 18, 2012 11:30 AM
Running925
Apr 10, 2007 10:03 AM
CRXdan
Dec 20, 2004 10:23 AM
turbo Si
Feb 1, 2003 03:59 PM
echo999
Dec 31, 2002 11:28 AM
