About to get head work done but have some questions...
Before I go on, I've been researching all morning because I knew absolutely nothing whenit came to head work, porting, polishing, yada yada.
I'm getting a port&polish, 3 angle valve job, upgrade the valve springs and retainers (to support 8,000 redline), bowl port and honing.
This is for a turbo Integra LS application car.
My questions being:
Since I'm only going to about 8,000 redline at most, what valvesprings and retainers are recommended?
The intake manifold; I've heard the Skunk2 and the JG Victor X manifolds flow well, but are they necessary? Will this be very restrictive if I leave the stock IM on? Would it be pointless to have this headwork done to not upgrade the intake manifold?
Is there anything else I should get done while the head is in the machine shop?
My questions being:
Re: About to get head work done but have some questions... (19sec beast)
with that much $ spent on head work, that $ money can be spent on a used type r head to do a ls/vtec change over.
Re: About to get head work done but have some questions... (95boostedteg)
I hear that LS/Vtecs aren't very reliable. I'd hate to think about throwing boost in the mix.
Yeah the victor x IM is nice and great fit w/no modifications to it. I like the Golden Eagle. You didnt mention Cams or cam gear with your built head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 19sec beast »</TD></TR><TR><TD CLASS="quote">I hear that LS/Vtecs aren't very reliable. I'd hate to think about throwing boost in the mix.</TD></TR></TABLE>
where did you hear that from? What part of town are you from? maybe i can show you some of my friends cars. They have b20 vtec, ls vtec, all boosted. It will be reliable and last as long, as long as you do it right the first time.
^^^^^BINGO!
ls/vtec blow because either they weren't tuned or they weren't put together correctly. Use the right parts, do it right the first time. If you don't cut corners and tune it, the ls/vtec is just as reliable.
Re: About to get head work done but have some questions... (Dunc)
I'm in Atlanta and I've never met anyone with a reliable, daily driven, ls/vtec.
I may have to look into it.
Anyone have any good links for info on the ls/vtec build?
Golden Eagle kit along with GSR oil pump/water pump to have a complete conversion, or else there is issues if you dont do them. Anyone that has the conversion wanna explain better.
HapaHaole
13
02-06-2006 08:01 AM
VNTEC
03-04-2004 09:15 PM
VNTEC
02-29-2004 08:45 AM
