ZC turbo?
Old May 24, 2005 | 10:42 AM
bennyhonda7's Avatar
Default ZC turbo?
anyone running obd1 zc dohc turbo setups? I can get one of these motors for free and believe it is a direct swap would this be a good motor for turbo? or should I just get a cheap d16z6?
Old May 24, 2005 | 10:48 AM
Loco Honkey's Avatar
Default Re: ZC turbo? (bennyhonda7)
Two cams = more tuning potential than one. ZC has a higher CR, but the difference is insignificant. If it's free and leakdowns OK, go for it.
Old May 24, 2005 | 10:51 AM
Default Re: ZC turbo? (Loco Honkey)
are the zc rods as strong as the z6?and if using uberdata could i use the p06 ecu with an ls map for a base?
Old May 24, 2005 | 11:54 AM
Couldn't tell you for sure about the rods. The ZC rods are the strongest D series rods, or they're just like any other D16 rod, depending on who you want to believe. I have no experience with Uberdata, so I can't tell you one way or the other. I'm a firm believer in Megasquirt, though, as I use it in my AllTrac, and if you're interested, you can PM me for my AIM name and I'll bend your ear something good.
SwissChEz82
Jun 8, 2005 07:30 PM
Seijuro Hiko
Jan 14, 2005 03:52 PM
quis23
Dec 10, 2003 08:20 PM
