strange fuel problems only after a fillup
Old May 20, 2005 | 09:59 AM
igo4bmx's Avatar
Default strange fuel problems only after a fillup
strange issue i have!
my car runs fine... even when its really low on gas (walboro 255 and 650 rcs)
as soon as i fill up my gas after driving it with really low gas, the car puts and struggles to stay idle when i start it back up...
is that normal?
Old May 20, 2005 | 10:07 AM
BoOsTeD C1's Avatar
bump...i too have same problem after fillng gas up but even if its either low or half a tank it struggles to start the car after 3 tries.
Old May 20, 2005 | 10:26 AM
igo4bmx's Avatar
Default Re: (VTEC_pWrD_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_pWrD_CiViC &raquo;</TD></TR><TR><TD CLASS="quote">bump...i too have same problem after fillng gas up but even if its either low or half a tank it struggles to start the car after 3 tries.</TD></TR></TABLE>
yeah i don't understand...
gas was near empty... started up fine....
drove a minute away to get gas, started it up, and "put put put"
Old May 20, 2005 | 10:40 AM
b18bturbo's Avatar
Default Re: (igo4bmx)
have you checked your fuel filters on both the cars.
Old May 20, 2005 | 10:41 AM
kameleon23's Avatar
i had this problem too. My tuner told me to turn the key on and off a few times before starting up my car after filling up with gas to increase my fuel pressure...i guess when you take the cap off your tank, your fuel pressure is gone. Seems to work for me
kaoss_11's Avatar
B A N N E D
I had that issue also it has something to do with the pressure in the tank or something my mechanic friend fixed for me but i have no knowledge of waht he did exactly. He messed w/ my vaccum hoses and fuel lines
Old May 20, 2005 | 10:57 AM
King Tut33's Avatar
Default Re: (kameleon23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kameleon23 &raquo;</TD></TR><TR><TD CLASS="quote">i had this problem too. My tuner told me to turn the key on and off a few times before starting up my car after filling up with gas to increase my fuel pressure...i guess when you take the cap off your tank, your fuel pressure is gone. Seems to work for me </TD></TR></TABLE>
Yep, definitely sounds like fuel pressure. You should hear it all escaping when you crack the fuel cap loose.
Old May 20, 2005 | 11:02 AM
igo4bmx's Avatar
Default Re: (King Tut33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by King Tut33 &raquo;</TD></TR><TR><TD CLASS="quote">Yep, definitely sounds like fuel pressure. You should hear it all escaping when you crack the fuel cap loose.</TD></TR></TABLE>
mine doesn't make a hissing noise when i take the cap off
Old May 20, 2005 | 11:10 AM
kaoss_11's Avatar
B A N N E D
mine does
Old May 20, 2005 | 12:47 PM
ginoboy1978's Avatar
Default Re: (kaoss_11)
Disconnect the evap purge solenoid. Should do the trick.
Make sure you have a obd1 though.....otherwise you'll get a cel.
DAN
Old May 20, 2005 | 12:58 PM
igo4bmx's Avatar
Default Re: (ginoboy1978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ginoboy1978 &raquo;</TD></TR><TR><TD CLASS="quote">Disconnect the evap purge solenoid. Should do the trick.
DAN</TD></TR></TABLE>
how about obd1 ecu on an obd2 motor?
StraightCivic
May 15, 2006 05:07 AM
sicivic
Jun 8, 2004 08:43 PM
pr0digy1
May 8, 2002 09:08 AM
itr0032
Jun 26, 2001 12:33 PM
