Fitting the new turbo in...
Old May 21, 2005 | 08:36 AM
B00STED Si's Avatar
Default Fitting the new turbo in...
quick question, im running a precision sc50 (.63 a/r 76-trim) right now, and i just ordered an sc61 (.63 a/r 52-trim) and with the sc50 i have the turbo mounted to the manifold with the compressor side on the left (inlet facing to the left) and its pretty damn close to the block.....Do you know if ill be able to run the SC61 the same way? is the compressor housing much larger than the SC50?? or will i have to run the compressor housing to the right side of the manifold (inlet facing to the right)...??? any ideas? thanks.
Old May 21, 2005 | 10:09 AM
Makdaddynuge's Avatar
You will prob have to have the compressor on the drivers side. What manifold are you using? Do you plan to run a/c with this setup?
Old May 21, 2005 | 09:13 PM
B00STED Si's Avatar
Default Re: (Makdaddynuge)
yeah, im gonna keep A/C. i have an inlinepro manifold right now. How big of a difference is the compressor housing from the SC50 to the SC61???
Old May 21, 2005 | 09:19 PM
mbdelsol's Avatar
Default Re: (B00STED Si)
with a rev hard mani on my friend car we had to grind a little bit of hte webing away from the block. not much at all we use a drimel.
Old May 21, 2005 | 09:47 PM
B00STED Si's Avatar
Default Re: (mbdelsol)
was that with an SC61?? what A/R ratio is the compressor housing? i dont think im gonna need to modify anything b/c i have about an inch of clearance so i shouldnt have a problem unless the SC61 housing is tremendously larger than the SC50.
Old May 21, 2005 | 10:03 PM
Tchleung's Avatar
The SC61 and the SC50 still sue the same T04E compressor housing so physically from the otuside, they will look the same.
Old May 22, 2005 | 05:31 AM
B00STED Si's Avatar
Default Re: (Tchleung)
oh ok, well then the should fit.... ill let everyone kno once i get it in.
sp00led
Jan 15, 2008 06:16 AM
mrbsponge
Jul 20, 2004 05:16 PM
tyflip2
Jan 24, 2004 10:16 AM
88CRXHybrid
Mar 7, 2002 12:32 PM
