turbo student: how to lower compression k20a2
how can i lower the compression on my engine?? what do i need to do??? i have rsx-s and want to go boost . what compression is perfect for my engine?? i want boost till 12 psi !!! any input will be appreciated
Re: turbo student: how to lower compression k20a2 (PePpeRedDc5)
thicker head gasket... but its a K motor just boost on stock compression but dont boost as high. you will make the same power at lower boost than somebody with lower compression and higher boost. its just a preference/safety thing. If you are using an FMU then get a low compression headgasket because tuning is not precise and bad things can(not always) happen. the choice is yours if you dont know and are scared stay away from boost. LOL JK. its fun but K motors are expensive dont blow it up.
imzjustplayin
12-27-2009 12:46 PM
rsx13k
05-25-2007 12:38 PM
RooskiGSR
02-28-2005 04:23 PM
