is this ok?
Old May 23, 2005 | 08:31 AM
coupon's Avatar
Default is this ok?
my car was tuned on open downpipe and when i daily drive it i run an exhaust made up of 4 extra ft of piping and a resonator on the end of it. would it be bad driving around with the exhaust i have on? like would it effect the a/f and run richer/leaner with it on?
Old May 23, 2005 | 08:37 AM
Turbowa's Avatar
Default Re: is this ok? (nlc)
It might a little. But the only way to be certain is to hook a wideband up to it and see how far off you are.
Old May 23, 2005 | 08:50 AM
coupon's Avatar
Default Re: is this ok? (Turbowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">It might a little. But the only way to be certain is to hook a wideband up to it and see how far off you are.</TD></TR></TABLE>
so i shouldnt drive around with the exhaust on?
Old May 23, 2005 | 08:58 AM
Turbowa's Avatar
I really wouldn't not knowing if its going to lean you out or not. If you get a chance to put a wideband on it then do it . If it must REALLY be on there then I'd say try to stay out of boost.
Old May 23, 2005 | 09:00 AM
coupon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa &raquo;</TD></TR><TR><TD CLASS="quote">I really wouldn't not knowing if its going to lean you out or not. If you get a chance to put a wideband on it then do it . If it must REALLY be on there then I'd say try to stay out of boost.</TD></TR></TABLE>
thanks, bump 4 info
Old May 23, 2005 | 09:21 AM
Quik Chris's Avatar
No.... you're fine w/ just the downpipe. This guy doesn't know what he's talking about.
Old May 23, 2005 | 09:30 AM
coupon's Avatar
Default Re: is this ok? (Quik Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik Chris &raquo;</TD></TR><TR><TD CLASS="quote">No.... you're fine w/ just the downpipe. This guy doesn't know what he's talking about. </TD></TR></TABLE>
so i can run my exhaust and it wont change anything? i daily drive with my exhaust currently and use open dp for the track (it was tuned on open dp)
Old May 23, 2005 | 11:53 AM
redzcstandardhatch's Avatar
something different
if it was tuned without the downpipe, putting some sort of exhaust on it is only going to make it a TINY bit richer, if any. sounds like you are putting a minimally restrictive (if any) exhaust on, so DONT WORRY ABOUT IT.
i gaurantee you'll have no problems relating to that exhaust. if your car was tuned well. i'd drive the crap out of it. have fun.
Old May 23, 2005 | 12:07 PM
tonydatyga's Avatar
Default Re: (redzcstandardhatch)
2nd that, 4 feet of piping and a resonator doesn't sound too bad. are there any bends and what kind (crush or mandre), what's the inner diameter? I wouldn't sweat it honestly. One run through a set of plugs and you'd know for sure
Old May 23, 2005 | 03:24 PM
coupon's Avatar
Default Re: (tonydatyga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">2nd that, 4 feet of piping and a resonator doesn't sound too bad. are there any bends and what kind (crush or mandre), what's the inner diameter? I wouldn't sweat it honestly. One run through a set of plugs and you'd know for sure</TD></TR></TABLE>
nope no bends, just a flex pipe at the end of the downpipe, a vband clamp holding the piping to it and just a "strait through" resonator on the end of the piping
Old May 23, 2005 | 07:45 PM
coupon's Avatar
LSTEG98
Mar 19, 2007 08:31 AM
june_si
Dec 5, 2006 08:00 PM
boostincoupe
Mar 22, 2006 08:37 PM
turbolshatch
Mar 15, 2006 07:32 PM
Accord94DX
Aug 14, 2003 02:50 PM
