What numbers with this setup
Ive just finished my boost project and just wondered what numbers i will be close to. Heres my setup:
94 Civic Sedan
B16a2
Garrret T25bb Turbo 82 a/r
2.5" dp into 2.25" hks super drager and test pipe
Tunertoys 450cc Injectors (high Impendence)
Walbro 255 fuel pump
AEM adjustable fpr
Hondata s200b
94 Civic Sedan
B16a2
AEM adjustable fpr
Hondata s200b
How much boost do you plan to run?
we made nearly 300whp with a modified T28 and 13psi on a b16a2
don't know the compressor map of a T25BB but i think this can be the region... maybe a bit less...
Malte.
Malte.
Im using stock internals so i dont want to boost more than 7psi. Do you think il blow the motor. Its being tunned by qualified hondata tuner.
7 psi is good. That's what I run at. I have a stock internal b16a with a Greddy 18G with basically the same exhaust dimensions as you only with 550 cc injectors and I get 203 whp on low grade fuel. I'm sure it would closer to 220 whp if I used higher grade fuel. It has been tuned by a professional as well. (The only tuner Grassroots MotorSports Magazine uses)
I've been running it since January. I just raced it this weekend over 2 days at an auto x. It did wonderful and hit the boost limiter a few times I am sure of. The BOV was nice and loud
