Turbo Gasket questions.. which way does this gasket go?
Does this gasket go a certain direction or does it not matter? it has an indention on one side. which way does the hump point to?
also does the oil return line gasket need any kind of sealer on it or leave it as is?
Re: Turbo Gasket questions.. which way does this gasket go? (88crxhfb16)
the turbo manifold gasket can go either way, it doesn't matter it is going to crush.
and the turbo return gasket doesn't need any type of sealer on it at all, just make sure that things are snug. oil doesn't flow out of the turbo with much pressure, it just kinda drains out. i hope this helps out, that looks like the start to a pretty nice set up, good luck.
Re: Turbo Gasket questions.. which way does this gasket go? (RaNMaN)
thanks bro,
here's a few pics its not finished yet though.
http://www.hondashowoff.com/profile.php?id=4833
