Cold start, large injectors
Old May 23, 2005 | 09:54 AM
ITR981002's Avatar
Default Cold start, large injectors
Was wondering if anyone has had the same "issue" as me. My car has 680cc injectors, if it hasn't been run for a while this is what it usually does. I turn the key and Immediatly 1 or 2 cyls fire but the car doesn't start. This happens so fast its seems as though it happens before the engine even has a chance to crank over once. Then I turn the key again, it cranks a few times... sometimes I have to blip the throttle but then it starts up... a little rough for a second or two, but then idles completely normal.
Does that sound like I have to add more or less fuel for my 'startup' or 'crank' enrichment? Or is that something that happens to you guys also. I don't mind it that much, the car always starts... just seems weird when it does that. Thanks!
Old May 23, 2005 | 10:30 AM
onefstek's Avatar
what type of fuel management are you using?
Old May 23, 2005 | 10:33 AM
ITR981002's Avatar
Default Re: (onefstek)
Sorry, should have mentioned that. I'm on Crome, stock Map sensor still.
Old May 23, 2005 | 10:55 AM
onefstek's Avatar
did u tune it for the size of injectors. and is it set up for cold start.
Old May 23, 2005 | 11:14 AM
ITR981002's Avatar
Yes, the injectors have been resized in crome... I've added a bit of fuel down low to compensate for the larger injector taking a larger base pulse to open. Once the car is warm it idles at 14.5-15.0 on my wideband. When its cold it idles slightly richer 13.0-13.5. I've not touched the 'startup fuel multiplier' in crome's fuel tools.
Old May 23, 2005 | 12:09 PM
onefstek's Avatar
i don't know about crome that much but I did work with Uber data a little bit.
does it have a way to change the fuel vs air temp and fuel vs water temp.
u might want to look into that and see if you can adjust it to get a better air/fuel. that might help with start up.
im using Apexi Power Fc and it also has a setting for ms (mili seconds) that ajusts the pulsation of the injectors.
Old May 24, 2005 | 10:43 PM
turtle-eg's Avatar
Default Re: Cold start, large injectors (ITR981002)
Lean it out a little, it's too rich.
Old May 25, 2005 | 08:31 AM
ITR981002's Avatar
Default Re: Cold start, large injectors (turtle-eg)
Once warm, it idles around 14.7-15.0 That's not rich at all. Maybe I need to take some fuel away from the Crank enrich however... i'll play with it.
OkPuddin
Honda CR-V & Element
13
Oct 9, 2018 03:44 PM
kteggy88
Acura TSX
Jul 22, 2015 05:15 AM
SIR_DREAM_KID
Feb 22, 2012 05:26 AM
turbo gsr2000
Feb 22, 2011 07:21 PM
abmerop18
Aug 1, 2005 09:42 AM
