boosted Integra gsr Need help
Hey guys i was wondering if any one knows why there is line from the oil pan connected to my turbo its probably oil and its leaking. i am running an fmax turbo kit and would apperciate any comments or help?is there any place where i could buy a replacement for this part or even after market where they sell these .another question is there supposed to be a whole in your oil pan?
thats the oil return and if its leaking from the turbo you can take the flange off the turbo and change that small gasket or unscrew the fitting and wrap it in teflon tape and tightne it up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">thats the oil return and if its leaking from the turbo you can take the flange off the turbo and change that small gasket or unscrew the fitting and wrap it in teflon tape and tightne it up</TD></TR></TABLE>actually its leaking from the oil pan
i think the person that drilled the whole in there did a shitty job.
http://www.cheapturbolines.com sells a good kit, but your problem seems to be a reluctance of use of a gasket between the draing and the oil pump? drain your oil pan and unscrew the fitting that is attached to it and check for a gasket, if not present, then purchase a gasket and gasket maker it if you must and you should be done.
I would suggest taking the pan off and fixing it the right way this way you no longer will have to worry about it . It would be a terrible thing it started to keak again withour you knowing and went dry. So deff take it off and reweld around the fitting coming out of the pan.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolingb20 »</TD></TR><TR><TD CLASS="quote">I would suggest taking the pan off and fixing it the right way this way you no longer will have to worry about it . It would be a terrible thing it started to keak again withour you knowing and went dry. So deff take it off and reweld around the fitting coming out of the pan.</TD></TR></TABLE>yea thats the way to do it.isnt there a kit that uses your drain plug ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by julian_gq »</TD></TR><TR><TD CLASS="quote">yea thats the way to do it.isnt there a kit that uses your drain plug ?</TD></TR></TABLE>
No the return line has to be above the oil. If it is in the oil it will not drain properly.
reignofchaos
Jul 31, 2003 07:48 PM
