Lucas oil stabilizer? and how much oil does stock pan hold?
is lucas oil stabilizer ok to use in a turbo? that stuff is sooo thick you have to squeeze it out of the bottle, but its supposed to stick to everything so there is no dry start up.
and how much oil will a stock pan take, both n/a and turbo? i could have sworn my old n/a took about 5-5 1/4 qts but the turbo only takes 4 1/2 with the filter filled as well.
and does moroso make an oil pan for d series motor?
Re: Lucas oil stabilizer? and how much oil does stock pan hold? (pyro_assassin)
That Lucas oil stabilizer is crap. Haven't you seen the test where they ran oil treated with it through a set of gears and it turned into froth at high speeds? It's as bad as putting Teflon chunks in your oil.
Re: Lucas oil stabilizer? and how much oil does stock pan hold? (beepy)
im using a little less than 1/2 qt lucas oil stabilizer along with just about 4 qts 10w40 in my boosted ls. the lucas oil made my car stop buring oil. ive heard it is bad for turbos, but on the bottle is says you can use it in all engines including diesels, and most of those are turbo, so..... i wouldnt use too too much lucas, but i think adding a tiny bit isnt gonna hurt much
Sprockets
08-08-2005 01:53 PM
