blow off valve install
i just rigged a turbo on my d16y5 an now i having problems getting the vacum lines right so it will boost. i think thats the problem because before i put on the bov it was boosting fine nopw its not boosting at all. so what could be some of the other problems. where do the vacuum lines get T'd off at?
I had the same problem as you. But I got it fixed. Hope this helps you.
1st: Make sure you got this line below:
2nd: Make sure you connected the line to the correct nipple on the bov. For example heres my type-s:
3rd: If that dont work. Go get a bigger T from lowes for example:
Hope that helped!
Hope that helped!
