FMIC blockin radiator
Old May 20, 2005 | 03:55 PM
D15B_Turbo's Avatar
Default FMIC blockin radiator
i just installed my greddy type 31 intercooler on my 93hatch... after installing it i notice my car runs hotter (according to stock temp gauge) probally because its blockin part of my radiator... is gettin a bigger radiator my only option...?
TIA...
Old May 20, 2005 | 04:07 PM
Brodie Bruce's Avatar
Default Re: FMIC blockin radiator (D15B_Turbo)
since it is getting close to the summer months, you could try running without the thermostat, but I would put it back in when the weather starts to cool down again. Another thing you could try is to wire up the fan so that it will have power whenever the ignition is on. These are probably the easiest/cheapest options
LoSt is BlaCk's Avatar
i didn't notice much of a preoblem with mine...you can get a dual core half size radiator...how much warmer is it running then before?
Old May 20, 2005 | 05:58 PM
Extreme's Avatar
Default Re: FMIC blockin radiator (xavenged7x)
The car will overheat without the thermostat.
That is because the coolant will circulate around the engine too fast to properly extract heat from the engine.
Try a dual core radiator, or integra radiator if the car has no a/c.
Old May 20, 2005 | 06:32 PM
SOHCD16y8's Avatar
you can cut the spring part of the thermostat out and still insert the housing part and it will restrict flow enough to cool but still flow higher than a stock thermo can.
Old May 20, 2005 | 06:35 PM
88crxhfb16's Avatar
fluidyne halfsized, never heard of anyone having overheating problems running one of these.
Old May 20, 2005 | 08:27 PM
Laserjock's Avatar
Default Re: FMIC blockin radiator (Extreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Extreme &raquo;</TD></TR><TR><TD CLASS="quote">The car will overheat without the thermostat.
Try a dual core radiator, or integra radiator if the car has no a/c.</TD></TR></TABLE>
you sure about that? the thermostat opens only WHEN the temperature gets hot and pops the spring in the thermostat. running without one will make your engine not as effecient cause it operates better at a certain temp range.
http://auto.howstuffworks.com/question248.htm
http://auto.howstuffworks.com/cooling-system.htm
please don't post stuff unless you are sure the info is correct. the internet is already full of useless crap.
Old May 20, 2005 | 10:01 PM
Extreme's Avatar
Default Re: FMIC blockin radiator (Laserjock)
In a nutshell: "running your car without a thermostat will make the water in the
radiator and the engine at the same temperature causing the temperature to rise
ever so slowly to the point of over heating. The purpose of the thermostat is to
keep the engine at a constant temperature, the water in the radiator is allowed to
cool the engine when required, the thermostat releases water to flow through the
engine keeping a constant temperature."
In D15B_Turbo's case, his problem will compound since he is blocking airflow to his radiator.
"please don't post stuff unless you are sure the info is correct. the internet is already full of useless crap."
Modified by Extreme at 6:58 AM 5/21/2005
Modified by Extreme at 6:59 AM 5/21/2005
Old May 20, 2005 | 10:53 PM
doubleA's Avatar
Cheaper options than a new radiator would be a better fan, Water Wetter or just use a little more water in your coolent mixture.
Old May 21, 2005 | 12:01 AM
D15B_Turbo's Avatar
thanks people for the quick responce...!
Old May 21, 2005 | 06:55 AM
14bcoupe's Avatar
Default Re: (D15B_Turbo)
y not just get the slim 12" radiator fan the guy sells here on honda-tech for $60 bucks shipped . its suppose to flow like 600cfm more than stock and free up some space(3") on the engine bay. and also get some thermal exhaust wrap for the manifold,downpipe to keep the engine bay cooler. this combo will def lower your engine temps and cost you under $100 bucks.
Old May 21, 2005 | 09:59 AM
5 Speed AP2's Avatar
Any updates on which method you plan to execute? Or have used? Any luck?
I got the same intercooler and having the same freakin problem.
Old May 22, 2005 | 05:18 PM
D15B_Turbo's Avatar
Default Re: (5 Speed Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Any updates on which method you plan to execute? Or have used? Any luck?
I got the same intercooler and having the same freakin problem.</TD></TR></TABLE>
nope havent thought of what im gonna do... i checked coolant levels and everythin... i guess its just time to save some money...!
Old May 23, 2005 | 04:35 PM
Damn. I just stopped driving my p.o.s.
Old May 23, 2005 | 04:48 PM
ITSME4G63's Avatar
well you can wire up your fans to run nonstop, that will help alot.
crxhybrid1320
Jul 1, 2011 06:01 PM
1 2 NV
Jan 31, 2007 08:38 PM
GReddy SI
Aug 1, 2004 11:47 PM
BB6-213
Jul 18, 2004 06:23 PM
EGh22aEG
Jan 9, 2002 06:37 PM
