Finally Turbod the D14..(kinda)..NEED HELP (car dont cranck/start) pics and vid
hello everybody.....
first off, this is the setup:
97 civic 1.4is (D14A4).
Tunertoys log manifold. (blocked WG flange)
garrett T3 .48/.67 internal wastegate.
SMIC.
2" chargepipes from the turbo to the intercooler.
2.5" chargepipes from intercooler to the TB.
hks super BOV.
Fasturbo oil lines.
NO DOWNPIPE YEY
GREEDY BLUEBOX.
ok here it goes...
i didnt start the car for about 3 weeks because i installed the turbo.
i tryed to start it today using booster cables from my dads cavalier,
i turned the key to "on" and everything was fine and the bluebox led blinked,
but when i tryed to cranck it nothing happend, just some starter motor clicking. (i think )
take a look in this vid and tell me what you think:
http://www.we-todd-did-racing....DE%3D
best regards moishik galimidi
SMIC.
hks super BOV.
Fasturbo oil lines.
NO DOWNPIPE YEY
GREEDY BLUEBOX.
ok here it goes...
Re: Finally Turbod the D14..(kinda)..NEED HELP (car dont cranck/start) pics and vid (RACEPAK)
I bet you knocked the spade terminal off the starter solinoid. Check that first.
Or it could be low battery voltage, test it and see. Sometime the jumper cables wont make a good connection so that could still be it.
Also check the ground connection on the thermostat housing. It a ring terminal with a 10mm head bolt holdingit in. Clean it with sand paper and reinstall.
Re: Finally Turbod the D14..(kinda)..NEED HELP (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">I bet you knocked the spade terminal off the starter solinoid. Check that first.
Also check the ground connection on the thermostat housing. It a ring terminal with a 10mm head bolt holdingit in. Clean it with sand paper and reinstall.</TD></TR></TABLE>
I agree with him.
I agree with him.
can you please explain this to a retarded man?
Re: Finally Turbod the D14..(kinda)..NEED HELP (RACEPAK)
on the starter there are 2 wires. one large one from the battery and one with a slide on connector. I think that slide on one might be loose.
Re: Finally Turbod the D14..(kinda)..NEED HELP (clutch878)
that video was scary, now i cant sleep at nights.
like the guys said you might have slid off the little starter cable by mistake, happend to me before, check all your grounds, its def power related nothing to do with the engine/tranny.
Mine has done this before....the power wire on my starter was too tight, it ended up turning more than just the nut. I turned it back a little, and it started right up.
don't know if that may be your problem, but it was mine.....GL
Look under the distributor on the top of your transmission, whats hes saying is the power wires to the transmisson has fallen off.
Re: (b16sedan)
hello again....
well i checked everything and i do mean everything ....
grounds
connectors
bluebox wiring
since than i tryed to start the car and it did cranckrd but it didnt start... (using other cars as battery)
what can be wrong??????
grounds
connectors
bluebox wiring
When you took the car apart (before the turbo install), did you disconnect the battery terminals? Or did you work on the car "live" with power on..if so, you may have shorted something out. Check fuses.
You need the following to run the car (timing and compression are assumed)
1.)Spark
2.)Fuel
3.)Air
1.)Spark
2.)Fuel
3.)Air
Re: (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">When you took the car apart (before the turbo install), did you disconnect the battery terminals? Or did you work on the car "live" with power on..if so, you may have shorted something out. Check fuses.
1.)Spark
2.)Fuel
3.)Air
yes i did dissconected the negativ terminal.
all of the folowing happend while i'm using booster cables from a runing car:
1- spark: i removed 1 plug and my man tryed to start the car and there was no spark while touching the manifold/block.
2- fuel: i can smell some fuel and i hear the fuel pump priming.
3- air: FI my man
1.)Spark
2.)Fuel
3.)Air
3- air: FI my man
Re: (RACEPAK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">
3- air: FI my man </TD></TR></TABLE>
common fellas help me here....
Re: (RACEPAK)
If there's no spark make sure the distributor is getting power (check the thick wire for +12V) and ground (check continuity from the distributor to the negative terminal on the battery). If those two check out, and I have little doubt they will, start taking stuff apart and replacing it piece by piece. Usually you can find a friend or someone that has a similar car to swap parts with temporarily... steal a distributor, steal their spark plug wires, etc.
Is it catching at all or just cranking? Are there any check engine lights?
Re: (raene)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene »</TD></TR><TR><TD CLASS="quote">If there's no spark make sure the distributor is getting power (check the thick wire for +12V) and ground (check continuity from the distributor to the negative terminal on the battery). If those two check out, and I have little doubt they will, start taking stuff apart and replacing it piece by piece. Usually you can find a friend or someone that has a similar car to swap parts with temporarily... steal a distributor, steal their spark plug wires, etc.
Is it catching at all or just cranking? Are there any check engine lights? </TD></TR></TABLE>
hello...
i dont have a thick wire on my dizzy, i have a connector with some wires on it.
how can i check continuity from the distributor??
as for the other questions...
no its not catching, just cranking.
no cel's
(il post a vid in a hour)
appreciate it
hello...
no cel's
appreciate it
Re: (RACEPAK)
no spark:
either the distributor is not working (ignitor is dead/not receiving power/not plugged in)
ecu is not sending a signal (bluebox is wired incorrectly/ecu is faulty/ecu isn't plugged in/wire is missing).
Re: (warrick)
this is how i connacted my bluebox:
Blue and Purple goes to A1
Orange and Yellow to A2
Brown to A 21
Gray to A 15
Black to A 26
Red to A 13
Green to D 7 ECU side
White to D 7 wire that goes to the map
CONNECTOR A :
CONNECTOR D :
what do you say?
Brown to A 21
Gray to A 15
Black to A 26
Red to A 13
CONNECTOR A :
CONNECTOR D :
what do you say?
Re: (no2unenolife)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by no2unenolife »</TD></TR><TR><TD CLASS="quote">check the dizzy</TD></TR></TABLE>
please tell me what to check????
uh, if your motor isnt turning over, your dizzys not going to be sending any spark. Did the motor start turning over then? Its either one of a few things, either the ground to the motor isnt connected (normally sits on top of the valve cover I think), you have a bad grounding point on the chassis, or your battery is just that dead. Switch the battery out for a known working (will start other cars) one.
