anyone here make up a custom interooler for the jrsc??
Old May 21, 2005 | 02:26 PM
93formula's Avatar
Default anyone here make up a custom interooler for the jrsc??
anyone make up a custom interooler for the jrsc??
did a search most pics are down on the archive section. need to know if this would be a DIY project.
other option was to use water injection
Old May 21, 2005 | 03:52 PM
nfn15037's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (93formula)
LHT Performance in Florida
Old May 21, 2005 | 03:58 PM
alpha's Avatar
http://www.lhtperformance.net/products.html
Old May 21, 2005 | 04:39 PM
93formula's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (0x64)
lol, i want something other then that, the lht i know about, but i dont want to spend 1k on a intercooler. just wondering if someone made a DIY kit
if i have to then ill use water injection.
Old May 21, 2005 | 06:02 PM
Si Shane's Avatar
way to say lol and be a dick about it, since you copmpletely neglected it in your first post.
Old May 21, 2005 | 06:10 PM
93formula's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (Si Shane)
how did i be a dick about it?????
maybe you should calm down and have a bit of sense of humour. and you didnt even respond in the first place so why do you care???
sorry if i wasnt super clear in my post
but the title does say anyone here make up a custom intercooler for the jrsc
Old May 21, 2005 | 06:53 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93formula &raquo;</TD></TR><TR><TD CLASS="quote">sorry if i wasnt super clear in my post
but the title does say anyone here make up a custom intercooler for the jrsc</TD></TR></TABLE>
Yes, LHT does, and if you don't like that one then bust out the 'ole TIG and make one yourself. It will probably cost you way more than $1k to buy the materials and pay yourself for the time involved. Good luck though!
Old May 21, 2005 | 06:56 PM
93formula's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (nfn15037)
okay so its that hard eh. thanks ill pass on the intercooler. LOL
i thought the intercooler setup may be a bit easier then that. ill look into the water injection.
Old May 21, 2005 | 08:23 PM
EnzoSpeed's Avatar
Argh, let me add some critical info...
1. The guy is looking for an intercooler for a D16.
2. LHT stopped making D-series parts. I talked to John (LHT) myself - he said there wasn't a big enough market to continue fooling around with d-series.
Search on hostboard. That is the JRSC forum.
Old May 21, 2005 | 09:05 PM
sharkcohen's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (EnzoSpeed)
Yup, no D or H series love from LHT.
Old May 22, 2005 | 06:51 PM
alpha's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">Yup, no D or H series love from LHT.</TD></TR></TABLE>
That's because not enough of them show love back
Old May 22, 2005 | 07:02 PM
JustinL's Avatar
having never dealt w/jrsc's, why wont a turbo i/c work with custom pipe(humor me, im uneducatedin sc's)?
Old May 22, 2005 | 08:28 PM
sharkcohen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0x64 &raquo;</TD></TR><TR><TD CLASS="quote">That's because not enough of them show love back </TD></TR></TABLE>
Well, I would disagree on that as far as the H22 JRSC users go.
Old May 22, 2005 | 08:30 PM
alpha's Avatar
Well, I would disagree on that as far as the H22 JRSC users go.</TD></TR></TABLE>
Comment wasnt towards the H22 people.
Old May 22, 2005 | 09:19 PM
ProjectDarkBlack's Avatar
Default Re: (pyro_assassin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pyro_assassin &raquo;</TD></TR><TR><TD CLASS="quote">having never dealt w/jrsc's, why wont a turbo i/c work with custom pipe(humor me, im uneducatedin sc's)?</TD></TR></TABLE> its a roots blower so it is a part of the intake mani TURBO IS BEST actually a friend of mine has a cool supercharged d-series, he even got it to trap at 105 with all 210 pounds of him in it
Old May 22, 2005 | 09:24 PM
rmcdaniels's Avatar
I made one a while ago. It worked, but was a PITA. I used a really cheap core, but you could use a better core without resorting to the big $ Laminova cores that LHT uses (of course those big $ Laminova cores will probably work better than whatever DIY contraption you build, but that's why they cost big $). I'm thinking a good motorcycle oil cooler core would work well, or at least better that the cheap POS core that I used. You need to have a big reservoir somewhere, like a gallon or two, or it will heat soak very quickly, I found that out from experience. It cooled off my charge air 20-30 degrees, even with my crappy DIY setup and a 20 oz reservoir (made by Dasani, only $1.00 pre-filled with water) but the biggest difference I noticed was that it just took a few seconds for my entire JRSC setup to cool off completely after a dyno pull. Before the intercooler it took a while in between pulls for it to cool off. Here's some pics of my DIY JRSC intercooler, I can't weld, so I made the whole thing with JB weld and a Dremel, and yes, I know, it's pretty sad.
Old May 23, 2005 | 05:56 AM
Si Shane's Avatar
Default Re: anyone here make up a custom interooler for the jrsc?? (rmcdaniels)
why not get a piece of metal to bolt inbetween the head and charger (as long as you have room between the firewall) and have it look like this from the side
&lt;--- | \/ |&lt;-----
So that when air goes inside this small rectangle (like a giant flange) it gets knocked down and out, or up and out. I would send it to a topmount ala WRX, and have it come back in through the other side. I have seen a FMIC on a crazy green/yellow hatchback with nothing on the inside but race car ****. Its got no dash, etc.
Old May 23, 2005 | 04:23 PM
EnzoSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Si Shane &raquo;</TD></TR><TR><TD CLASS="quote">why not get a piece of metal to bolt inbetween the head and charger (as long as you have room between the firewall) and have it look like this from the side
So that when air goes inside this small rectangle (like a giant flange) it gets knocked down and out, or up and out. I would send it to a topmount ala WRX, and have it come back in through the other side. I have seen a FMIC on a crazy green/yellow hatchback with nothing on the inside but race car ****. Its got no dash, etc.</TD></TR></TABLE>
There are two problems:
1. Moving the charger even the slightest bit means you need to find a bigger belt somewhere.
2. Because the intake manifold studs are barely long enough to begin with, you'd need to get longer studs to go through the extra flange.
Anyway, I've seen a guy who had done something similar to that without inserting the extra metal piece. He cut open the manifold and welded in a slanted piece of sheet metal which forced the incoming air upwards. Then he drilled a large hole in the top where the air exited. Actually, let me go draw a diagram.
Old May 23, 2005 | 08:58 PM
rmcdaniels's Avatar
I've seen a guy mount the blower on a metal plate where the A/C compressor sits, he just ran it out of a flange to a FMIC.
Old May 24, 2005 | 08:22 AM
tthame1's Avatar
Default Re: (rmcdaniels)
Holy crap thats a ghetto-*** i/c setup.
Old May 24, 2005 | 09:18 AM
rmcdaniels's Avatar
Default Re: (tthame1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tthame1 &raquo;</TD></TR><TR><TD CLASS="quote">Holy crap thats a ghetto-*** i/c setup. </TD></TR></TABLE>
If you think that's ghetto, then you should see my twin-charger setup:
http://www.hostboard.com/cgi-b...12303
Old Jun 5, 2005 | 09:19 PM
93formula's Avatar
hey thanks for the pics.
it does look ghetto, but atleast it works, right? LOL
ill keep it in mind.
hondaapi
Jul 12, 2006 03:50 AM
2K Teggy
Mar 10, 2004 07:53 AM
92TEGsrSC
May 7, 2003 11:15 AM
TGUNNER
Jun 11, 2002 07:58 PM
