Advice needed for RSX with forged internals and Nitrous
Well, I opted to sell my turbo because I was spending too much $$ .
So This is the stuff that I ended up keeping
9:0:1 pistons
eagle rods
Methanol injection kit
Hondata K-pro
255 walboro pump
750 cc injectors
So my question is, what do you guys suggest I should do as far as set up. I'm looking for least expensive, but nothing dangerous. ie: a 200 shot on a dry kit. It just doesnt look safe.
So, I need a suggestion on kit and what do I need of the above for a good reliable set up.
Is K-pro an over kill? will I just be alright with stock injectors and getting a direct port? how many shots would you guys run? is the methanol still going to aid like it did on turbo for anti detonation and higher octane level?
thanks
9:0:1 pistons
eagle rods
Hondata K-pro
255 walboro pump
750 cc injectors
thanks
Re: Advice needed for RSX with forged internals and Nitrous (zulustypes)
If the bottom end is built you might as well do a multi stage setup. First stage being a 75 - 100 dry shot and the second stage being 150 - 175 dry shot. Your compression is a little low but nothing some N20 cant help with Keep the KPro.
Turbolude
12-14-2001 07:10 AM
