Read ECU error code with OBD2 - OBD1 conv. harness!?
Old May 24, 2005 | 05:47 AM
agratise's Avatar
Default Read ECU error code with OBD2 - OBD1 conv. harness!?
Hi,
is it possible to read a error code which the ECU detects while driving on a car with OBD2 to OBD1 conversion harness. Its a 1999 Honda Civic with P28 ECU. It should be possible that someone tells me which two ins on the ECU i have to connect to make the CEL blink!
Thanks,
Philip
Old May 24, 2005 | 06:17 AM
tgreaves's Avatar
Default Re: Read ECU error code with OBD2 - OBD1 conv. harness!? (agratise)
You need to ground out pin D4 on the obd1 harness and your CEL will flash the codes..
Crazy_SI_T
Sep 23, 2012 04:55 PM
ej6turbo
Aug 8, 2012 02:48 PM
beseman
Aug 24, 2006 10:18 AM
NsX_CrX
Nov 19, 2005 12:49 PM
