Small scratch on Crower cam. Repairable?
Old May 19, 2005 | 09:41 PM
DragSource's Avatar
Default Small scratch on Crower cam. Repairable?
I have a set of crower 403 cams that I was hoping to run on my LS setup, but I have discovered that one of them has a small scratch on the cam gear end.
The scratch is not very deep, but I can feel it with my finger.
Here is a very crappy picture. I apologize for my cheapness when buying my digital camera
Any suggestions/info would be greatly appreciated. Thank you!
Old May 19, 2005 | 10:11 PM
97BLACKCIVIC's Avatar
if im not mistaken, you can have it micropolished. bump, cuz im curious.
Old May 20, 2005 | 05:16 AM
DragSource's Avatar
Default Re: (97BLACKCIVIC)
::: bump :::
Old May 20, 2005 | 08:00 AM
Si Shane's Avatar
Default Re: (DragSource)
try changing yuoir camera from FAR object to CLOSE object. I bet there is a switch you dont know about.
Old May 20, 2005 | 08:07 AM
DragSource's Avatar
You're probably correct. . . I need to figure this thing out. . . was trying to cover flash with my finger
<---- loser
I'll fiddle with it when I get off work (in 12 hours)
If I take this to a local machine shop and have them micropolish the scratch out to the best of their ability. . . do you think it will be a problem.
The part that is scratched looks to sit right under the end cam cap on the timing belt side.
Old May 20, 2005 | 08:12 AM
SPOOLINmatt's Avatar
dont worry about it, but if you do wanna worry, just take it and have it polished. no big deal.
Old May 20, 2005 | 08:39 AM
PM-Performance's Avatar
Default Re: (SP00LIN)
Would it matter since its not on a lobe?
I dont thinkit would matter at all, but I could be wrong.
Old May 20, 2005 | 08:55 AM
DragSource's Avatar
Starting to feel better already. . .
Anyone else?
Old May 20, 2005 | 10:23 AM
FredoSP's Avatar
Default Re: (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 &raquo;</TD></TR><TR><TD CLASS="quote">Would it matter since its not on a lobe?
I dont thinkit would matter at all, but I could be wrong. </TD></TR></TABLE>
I was thinking the same thing
Old May 20, 2005 | 10:28 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (FredoSP)
i wouldnt run that cam unless you plan on buying a new head in the near future, any scratch like that will tear up the cam journals which could lead to seizing up the head etc etc etc
take it to a machine shop and see what they say, but i def wouldnt run it with a scratch you can feel
brian
Old May 20, 2005 | 10:37 AM
DragSource's Avatar
ewwwww. . .
If I do get the scratch micropolished out. . . will that end of the cam be "out of balance" so to speak. . .and smaller? Would it then have play on that end. . . causing premature wear also?
Old May 20, 2005 | 11:46 AM
Thurman Merman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragSource &raquo;</TD></TR><TR><TD CLASS="quote">ewwwww. . .
If I do get the scratch micropolished out. . . will that end of the cam be "out of balance" so to speak. . .and smaller? Would it then have play on that end. . . causing premature wear also?</TD></TR></TABLE>
if thats the case, then for good measure, when you take it to have it micropolished, have them do both ends to match the counterweight so everything is in balance.
EDIT: actually, if a machine shop does mircopolish each end to "keep in balance", would that process take off enough surface material to have the journals not properly fit anymore?
Old May 20, 2005 | 11:57 AM
DragSource's Avatar
Default Re: (Thurman Merman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thurman Merman &raquo;</TD></TR><TR><TD CLASS="quote">
EDIT: actually, if a machine shop does mircopolish each end to "keep in balance", would that process take off enough surface material to have the journals not properly fit anymore?</TD></TR></TABLE>
That is exactly what I was wondering
Old May 20, 2005 | 12:24 PM
nfn15037's Avatar
Which way does the cam rotate? Does it spin along its long axis or twirl around like a baton? If yours does the latter then I would be worried more about that than the balance of the cam
Seriously though, get it micropolished. They don't really remove much material at all then plastigauge the journal after the polish to make sure oil clearances are right.
And use the little flower (macro) setting on your digicam for up close pix
Old May 20, 2005 | 12:55 PM
DragSource's Avatar
So if micropolishing doesn't get the scratch completely out, and there is still a slight mar in the cam, am I hosed?
Or is it in a non-critical area. I'll have to inspect it more closely this evening, but it may not sit directly under the cap where there's only a thin layer of oil separating metal from metal.
I'm at work and having a memory lapse. . . but does the cam cap on the timing belt side of the motor have a hollow spot on the underside?
Old May 20, 2005 | 01:48 PM
earl's Avatar
If I could see the scratch I could tell more. It is probably ok to run after micropolishing even if the scratch can still be felt. It will store a little exra oil in it.
Old May 20, 2005 | 02:20 PM
Default Re: (coptzer)
run it, most of you could take your cams out after youve been running them this long and look at the timing gear end and it will be all worn looking, and youll be like woah, but the cam doesnt do **** except spin and it doesnt have any slinging motions, that scratch wont hurt anything, just polish it and run it.
Old May 20, 2005 | 02:40 PM
DragSource's Avatar
Done deal. I will run it.
I will take a better pic tonite for you guys. That one above is a joke - sorry.
I downloaded the instruction manual to my camera today while at work, and read through it. . . I think I can handle it now
Old May 20, 2005 | 02:44 PM
BodyKits NW's Avatar
Default Re: Small scratch on Crower cam. Repairable? (DragSource)
You'll be alright. Just polish it up a lil and make sure it's smooth.
Old May 20, 2005 | 08:32 PM
DragSource's Avatar
Default Re: Small scratch on Crower cam. Repairable? (BodyKits NW)
I'll never get the hang of the digi
The flower is on. . .flash is off. . . I suck
As it turns out, after getting home and checking it out - the scratch is not on a surface that appears to touch anything. The spot it's on doesn't look like it will create friction with any other parts.
I'm going to have it micropolished anyways, for sanity reasons. (I don't want to be paranoid about it when the build is FINALLY done)
Thanks for the input and suggestions guys
Old May 20, 2005 | 08:55 PM
turbodohcsi's Avatar
"i wouldnt run that cam unless you plan on buying a new head in the near future, any scratch like that will tear up the cam journals which could lead to seizing up the head etc etc etc
take it to a machine shop and see what they say, but i def wouldnt run it with a scratch you can feel"
that exacty thing happened to me, my cam just locked up and would not spin for **** and locked my head up. so needless to say im in the market for a new head and some cams, i would be VERY cautious about running it. and if you take it to a machine shop, make sure they know about hondas cause I BELIEVE a lot of v8 heads have like bearings for their cam or cams.
Old May 21, 2005 | 05:11 AM
DragSource's Avatar
Default Re: (turbodohcsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbodohcsi &raquo;</TD></TR><TR><TD CLASS="quote">
that exacty thing happened to me, my cam just locked up and would not spin for **** and locked my head up. so needless to say im in the market for a new head and some cams, i would be VERY cautious about running it. and if you take it to a machine shop, make sure they know about hondas cause I BELIEVE a lot of v8 heads have like bearings for their cam or cams.</TD></TR></TABLE>
I think I'm going to end up allright on this one.
The cam cap on the end is kinda hollow. It just so happens that the scratch resides perfectly in the "void" of the cam cap.
Crossing my fingers anyways. . . I just can't bring myself to buy another set of 403's.
Old May 21, 2005 | 09:15 AM
earl's Avatar
as long as you polish it so that there are NO raised areas above the surface diameter of the journal, there is NOTHING to cause anything to sieze. The deeper part of the scratch becomes nothing but an oil channel.
Old May 21, 2005 | 11:55 AM
DragSource's Avatar
That's good to know!
I can sleep now
All I'm missing for my build is the bottom end.
Working overtime saving up $2000 or so to send your direction earl. Been having to spend $ on the house to keep the old lady happy. . . my turn .
Old May 21, 2005 | 01:01 PM
Jared's Avatar
Having trouble seeing the pic properly, but is the spot you're seeing the scratch where the cam seal rides?
h224thgensedan
35
Mar 19, 2009 04:44 PM
MIDnightblackDA
Dec 31, 2005 12:25 AM
d357r0y
Jul 30, 2004 04:47 PM
Nerologic
Feb 6, 2004 10:45 PM
