Wierd cel code kill me now
Old May 23, 2005 | 04:25 PM
NewportSI's Avatar
Default Wierd cel code kill me now
I just got my ecu back, its a p28 in a b16 with a drag kit rc440, hondata is fine no blinking light, car runs fine, i have a 2 pound boost cut till i get it tuned... The problem is i have a check engine light, i check it and it blinks once every 5 secs, is this code 1 or wtf, im gonna drive off the bridge tonight if i dont fix this lol
Old May 23, 2005 | 04:42 PM
dustin's Avatar
Default Re: Wierd cel code kill me now (NewportSI)
Check your O2 sensor.
Old May 23, 2005 | 05:18 PM
NewportSI's Avatar
Default Re: Wierd cel code kill me now (dustin)
check it for what ? is it a code 1, or is it just blinking every 5 seconds casue my car hates me
Old May 23, 2005 | 05:25 PM
turboteg2nv's Avatar
your car just hates you.
j/p CHECK to see if your o2 sensor is functioning, if that is what the code is for.
Old May 23, 2005 | 05:27 PM
NewportSI's Avatar
Default Re: Wierd cel code kill me now (turboteg2nv)
how do i check to see if it is working properly, my o2 was fine before turbo install, i havent driven on it more then 50 miles..
Old May 23, 2005 | 06:03 PM
NewportSI's Avatar
bump for 3 peanut butter and jelly sandwiches
Old May 24, 2005 | 05:12 AM
EE_Chris's Avatar
The O2 spits out a voltage. In order to see what the voltage is, you need a multi-meter. Do you have one?
How many miles were on the O2 before you went turbo? Maybe it was on its way out and now you're running rich enough to just foul it out completely.
Old May 24, 2005 | 02:45 PM
NewportSI's Avatar
Default Re: Wierd cel code kill me now (EE_Chris)
there was only 69k when i went turbo, ill check the voltage, im sure my friend has the meter needed... what happens if i dont replace the o2 sensor right away if it is bad or whatever?? will anythign get fucked ?
Old May 24, 2005 | 08:24 PM
MONTCO Si's Avatar
what happens if u dont replace the 02 sensor? well u wont have a accurate A/F reading it might read pig rich all the time or lean whatever it may be stuck at, and u will still have that CEL that is bothering u so much
Old May 24, 2005 | 08:31 PM
IloveNewt's Avatar
Default Re: Wierd cel code kill me now (MONTCO Si)
It is probably a glitch with HONDATA that a LOT of people seem to be having.
Post here to let HONDATA know about this.
http://hondata.net/forum/viewtopic.php?p=8399#8399
914b16
Sep 26, 2007 08:22 AM
fmax420
19
May 7, 2007 05:26 PM
ProLineDesigns
Mar 28, 2006 05:20 AM
bumpin_bass
Dec 30, 2002 05:53 PM
