The difference in Turbos
Old May 23, 2005 | 07:38 PM
crj_lll's Avatar
Default The difference in Turbos
Does anyone know the difference to T1. T2, T3 and a T4 turbo?
Old May 23, 2005 | 07:52 PM
s2kdre's Avatar
Default Re: The difference in Turbos (crj_lll)
those are different size flanges where they bolt to the manifold.
adseguy's Avatar
they are different sizes. There are no T1's or T2's that I know of. It goes T15 (you'll never use this) T25, T3, T04 (housing hybrid), T4. Many people combine sections like a small T3 turbine section (the exhaust side) and a bigger T04 compressor side (the intake side). Sizing a turbo is necessary so you get either minimal lag or good top end power. Usually people sacrifice a little of both to get a good power band. Keep searching and read up on people's setups
http://www.beesandgoats.com/bo....html
Go half way down weher he explains turbo sizes a little bit. A lot goes into a properly sized turbo.
A/R size, trim size, housing size, wheel stage, efficiency
Old May 23, 2005 | 08:01 PM
crj_lll's Avatar
Default Re: The difference in Turbos (adseguy)
What is the smallest turbine and exhaust combination?
Old May 23, 2005 | 08:14 PM
adseguy's Avatar
?...doesn't make sense dude
You could do a tiny *** T25 setup and reach full boost at like 2000 rpm, but your top end would suck big ***, so no good for racing. READ UP!
Old May 24, 2005 | 08:18 PM
crj_lll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">?...doesn't make sense dude
You could do a tiny *** T25 setup and reach full boost at like 2000 rpm, but your top end would suck big ***, so no good for racing. READ UP!</TD></TR></TABLE>
Thanks for the answer. T25. That is what I want. Full spool by 2000K I am working on something else. Just gathering small facts, peice by peice.
Old May 24, 2005 | 09:59 PM
r north's Avatar
i have a T25 from a S13 that i thought about using. now it's just sitting in my room collecting dust.
Kid-jdm-teggy
May 1, 2014 04:48 AM
rx7_
Dec 14, 2009 07:11 AM
dustinz_em1
Nov 25, 2007 05:41 AM
eddie1681
Mar 27, 2002 02:42 PM
