oil return with moroso oil pan
is it just me or does the moroso oil pan pretapped oil return hole puts the oil return in a wierd spot, I am using a blox manifold and I face the turbo compressor to the passenger side, and the oil pan hole is really far away from the turbo drain hole. plus its so low the holes are almost on the same level.
I dont have any pics because I discover this while fitting the kit together.
Re: oil return with moroso oil pan (rudebwoy)
I used to have a Moroso pan with a drag manifold on a B16 and didn't have any fitment issues with the return line.
Re: oil return with moroso oil pan (JMinSi2000)
I think it all dedends on how you place the compressor of the turbo. but its too late for me because my whole kit is setup for the compressor to be on the passenger side. this sucks! I hope there will be no flow issues.
I am also using a blox mani which also suck ***. even with a wastegate elbow there is a problem with fitting a dump tube.
orange.honda
05-06-2003 04:14 AM
