Traction bar clearance problems?
I'm about to purchase some traction bars, but I'm worried about ordering them, and then not being able to clear the intercooler piping. I'm currently using a Fluidyne 38mm full-size radiator and my intercooler piping runs right behind the turn signals.
My main question being; what traction bars do you use and did you have to alter your intercooler piping to make them fit?
check out http://www.full-race.com or give them a call I am sure they can help you.
I had to cut the pipe that comes off my turbo compressor about 2" to get my driver's side bar to fit, the passenger side no issues. My driver's side bar also rubs on my Moroso oil pan, I assume you have a stock oil pan, so you won't have any problems.
my full-race bars cleared my moroso pan on my eh6 no problem. the front cross member went right under the feet of the radiator, so i had to bend those tabs up a little bit though. i had the FR back-door kit, so i had no ic pipe issues at all.
platinum00
Jan 20, 2006 11:28 AM
