CP, JE, and Wiseco
Old May 23, 2005 | 07:22 AM
Dunc's Avatar
BCICAN
Default CP, JE, and Wiseco
I tried to search, but the words are too short.
Question: Can anyone list the differences in quality and/or performance between these three pistons? It will be for a "higher" power application....I want to keep it around 600whp. Range would be 550 absolute minimum and about 650 maximum.
Old May 23, 2005 | 07:38 AM
11psiTurboSI's Avatar
Default Re: CP, JE, and Wiseco (Dunc)
All 3 companies will do the job.
Old May 23, 2005 | 07:52 AM
X-Mazda 3 Racer's Avatar
May I suggest Arias
http://www.ariaspistons.com
I use them in everthing from 200 h.p. street cars to my 1200 h.p. ProFWD car.
Old May 23, 2005 | 08:22 AM
Boostfed's Avatar
New User
Default Re: CP, JE, and Wiseco (GoldenEagleMfg.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldenEagleMfg.com &raquo;</TD></TR><TR><TD CLASS="quote">May I suggest Arias
I use them in everthing from 200 h.p. street cars to my 1200 h.p. ProFWD car.</TD></TR></TABLE>
I have to agree!! My new build up is using Arias 83mm slugs in my Golden Eagle sleeved GSR! Tom Jung is a very helpful guy at Arias too!
Old May 23, 2005 | 11:45 AM
Dunc's Avatar
BCICAN
Default Re: CP, JE, and Wiseco (Boostfed.com)
So you guys would suggest the arias pistons then huh? There is still time for me to decide I guess. The motor is going out on wednesday, and I am just looking for as more reliablity than a huge number on a screen as possible (even though I am looking for about 600whp). Thanks for the help guys.
Old May 23, 2005 | 12:53 PM
civicross's Avatar
I've used Arias personally.
All of the "big" companies, CP, Wiseco, Arias, JE, etc, will do the job just fine. Its more or less personal preference. Tom at Arias is VERY helpful.
Old May 23, 2005 | 01:49 PM
Motorhead_AZ's Avatar
Default Re: CP, JE, and Wiseco (civicross)
Arias pistons are the heaviest of the bunch (according to a test conducted by IB). I would go with Wiseco. That's what I have. Endyn pistons are also great.
Old May 23, 2005 | 02:04 PM
civicross's Avatar
Default Re: CP, JE, and Wiseco (Motorhead_AZ)
Call Arias and ask for lighter pistons?
Old May 23, 2005 | 02:06 PM
ITSME4G63's Avatar
good ol je slap, id say go with wiseco if you can.
Old May 23, 2005 | 02:11 PM
z6's Avatar
z6
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motorhead_AZ &raquo;</TD></TR><TR><TD CLASS="quote">Arias pistons are the heaviest of the bunch (according to a test conducted by IB). I would go with Wiseco. That's what I have. Endyn pistons are also great.</TD></TR></TABLE>
heavier piston means one of 2 things...more dense metal or more meat on piston
either way on all three pistons the ringlands will go one day
Old May 23, 2005 | 03:02 PM
Default Re: CP, JE, and Wiseco (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">
heavier piston means one of 2 things...more dense metal or more meat on piston </TD></TR></TABLE>
How about a 3rd thing called heavier rotating assembly??
Old May 23, 2005 | 05:20 PM
Teglove2's Avatar
Everyone I know runs Wiseco from everything from 300whp to over 500whp. Free skirt coating and the lightest off all the pistons. Not to mention good price, btw, I work for Wiseco, heeh
Old May 23, 2005 | 06:37 PM
Garcia-Racing's Avatar
I would and do run CP's. Wouldn't change to any of the others as long as I have a choice.
Old May 23, 2005 | 07:16 PM
Dunc's Avatar
BCICAN
Default Re: (Garcia-Racing)
Well is there any proof or comparisions to show me which piston is better. Or some literature describing pros and cons of each piston? I would just like to be able to read about each one to make an informed decision. Ooor is this all just a personal choice/preference?
Old May 23, 2005 | 07:25 PM
SOHCmaster's Avatar
Arias is the real winner, but like CP as well...
Old May 23, 2005 | 08:09 PM
vaporboy12's Avatar
Default Re: (PK SPEED)
Arias is what i have in my built motor.
How about a 3rd thing called heavier rotating assembly?? </TD></TR></TABLE>
if you have turbo you shouldnt have to worry about a few extra grams.
Old May 23, 2005 | 08:12 PM
There are certain tests that can be done to test pistons, but honestly it is personal choice. I would run any of the others if I was sponsored by them and got them from for free or really cheap, but since I pay like everyone else, I run CP's.
Old May 23, 2005 | 08:33 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garcia-Racing &raquo;</TD></TR><TR><TD CLASS="quote">There are certain tests that can be done to test pistons, but honestly it is personal choice. I would run any of the others if I was sponsored by them and got them from for free or really cheap, but since I pay like everyone else, I run CP's.</TD></TR></TABLE>
Just as I thought. Thanks for all the input Garcia...
Old May 24, 2005 | 07:15 PM
SOUNDEFFECTS's Avatar
Default Re: (Dunc)
I beat the living crap out of my JE pistons with 2 different builds...never smoked, never gave out on compression numbers. Then again I have used CP pistons with great success too.
Old May 24, 2005 | 08:35 PM
Widebody1's Avatar
All of the company's make there top of the line piston from 2618 alum alloy.... That material is used in most high end apps but it expands and contracts more than other piston materials meaning "wear"... Where the meat is, "how thick the crown is and the skirts." has to do with the different manufacturers, differences in ringland placement, i forget the term but the holes wiseco pistons have where the oil ring goes "for faster break in". There are different designs and thats about the only things that make them unique. All are good forgings for the kinda power you want, it has a lot to do with personal preferance.
The pistons that are made to make the most power arent the ones that will last 100,000 miles. Most people that make alot of power and have a built engine dont rely on the car to be daily driven. I have always heard good of CP also and i will use those.
P.S check into piston ring stuff because there are pro's and cons to a moly ring vs. and chrome ring. C-ya on CSS
Modified by Widebody1 at 9:55 PM 5/24/2005
Old May 24, 2005 | 09:49 PM
careawholelot's Avatar
Default Re: (Widebody1)
wiseco
1junkycivic
Aug 15, 2008 12:40 PM
DRIVENRacing
Dec 5, 2005 08:50 AM
igo4bmx
Jan 8, 2005 09:32 PM
account deleted
Sep 5, 2003 11:02 PM
