cooling q's
Old May 24, 2005 | 10:27 AM
budget's Avatar
Default cooling q's
right now my water to coolant mixture is about 60water/40coolant is that ok for the summer? (hot tx weather) should i run water wetter?
also heard about ppl getting aftermarket radiator caps, what makes them different better than stock ones?
Old May 24, 2005 | 12:05 PM
budget's Avatar
Default Re: cooling q's (Straight Flush)
Old May 24, 2005 | 12:06 PM
FOrSfEd's Avatar
thats what I run though I'm in South Carolina
Old May 24, 2005 | 07:55 PM
budget's Avatar
Default Re: cooling q's (FOrSfEd)
water wetter? radiator caps?
Old May 24, 2005 | 09:38 PM
ProjectDarkBlack's Avatar
Aftermarket radiator caps will hold in more pressure, which raises the boiling point of the mixture
Old May 25, 2005 | 08:31 AM
budget's Avatar
Default Re: cooling q's (ProjectDarkBlack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectDarkBlack &raquo;</TD></TR><TR><TD CLASS="quote">Aftermarket radiator caps will hold in more pressure, which raises the boiling point of the mixture</TD></TR></TABLE>
Old May 26, 2005 | 07:12 AM
budget's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Straight Flush &raquo;</TD></TR><TR><TD CLASS="quote">
also heard about ppl getting aftermarket radiator caps, what makes them different better than stock ones?</TD></TR></TABLE>
anybody?
Old May 26, 2005 | 07:15 AM
adseguy's Avatar
are you overheating or something....you realize that the radiator only tries to keep the same temp all the time (about 180-200). Don't change anything unless you have problems
Old May 26, 2005 | 08:13 AM
budget's Avatar
Default Re: cooling q's (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">are you overheating or something....you realize that the radiator only tries to keep the same temp all the time (about 180-200). Don't change anything unless you have problems</TD></TR></TABLE>
its not overheating but running a lil hot
Old May 26, 2005 | 10:08 AM
adseguy's Avatar
what do you mean a little hot? How do you know? A turbocharged engine runs a little hotter anyway and underhood temps will be hotter as well. Have you bleed the system?
crx-si
24
Aug 3, 2008 05:27 PM
prelude_93vtec
Jul 9, 2007 06:43 PM
ScoobCivic
Nov 19, 2004 09:22 AM
SupaFly_Honda
Oct 21, 2003 08:33 AM
B_1_8_hatch
Jul 15, 2003 09:22 PM
