Oil drain with drag kit B16
Please post pics, or tell me where i can find some, I need a pic of a drain line with the drag manifold on a b16... i have a moroso street pan, and just wanted to see how you did it...
Re: Oil drain with drag kit B16 (NewportSI)
Here are some pictures of my old setup. I had a drag manifold and then switched to an OBX manifold but the oil return worked for both. Its not a very good picture but I used two 90 degree fittings to come around the downpipe and into my Moroso oil pan. I'm actually trying to sell this return line if you are interested, $50 shipped. Email me at dennisflossnsol@msn.com
Re: Oil drain with drag kit B16 (DD93eg)
Anyoone with a pic with a drag mani and dp, and where i can see the line..
BTW thanks for your pic DD93eg
Modified by NewportSI at 6:45 PM 5/22/2005
Do you have the same oil pan that I had? If you do, than you can either route your return behind the downpipe as I did or you can use 1 90 or 45 degree fitting out of the turbo and run it in front of the downpipe and straight into the oil pan. Just another option for you with that Moroso.
Yes i have the steel one that looks stock, bungs are in the same spot, moroso street or whatever they call it.. Im going to play around with it today
boredracer408
11-16-2003 04:26 AM
KC GSR
02-04-2003 02:33 PM
