my seals are going bad
Old May 24, 2005 | 07:14 AM
redlseg's Avatar
Default my seals are going bad
my seals are going bad on my garret t-4 and its blowing some smoke out my exhaust. i really want to keep the turbo but i've heard once u rebuild it, it will never be the same. and the new seals will go out quick. is this true?
Old May 24, 2005 | 07:18 AM
Finland's Avatar
a turbo doesn't really have seals, they are more like little tiny piston rings. The rings can be replaced easily, but if the groove that the ring slides in is worn, then you need to replace the shaft as well. Most people will recommend that you have it balanced after you put it back together.
JonGP4
Nov 22, 2003 09:33 AM
Turbo Lude SH
Oct 14, 2002 08:55 PM
bruthaboost
Jul 30, 2001 05:36 AM
