Oil Return line is leaking
Old May 21, 2005 | 09:12 AM
abmerop18's Avatar
Default Oil Return line is leaking
I have tried everything, and the return line for my turbo still leaks pretty bad. I have clamps on both ends, and loaded both fittings and taps with a shitload of jb weld and liquid gasket, but it still continues to leak. the turbo is brand new, so it cant be that leaking. anyone have any ideas on what to do?
Old May 21, 2005 | 09:28 AM
tilt's Avatar
Default Re: Oil Return line is leaking (abmerop18)
try some rtv where the hose clamps down.
Old May 21, 2005 | 09:40 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abmerop18 &raquo;</TD></TR><TR><TD CLASS="quote">I have tried everything, and the return line for my turbo still leaks pretty bad. I have clamps on both ends, and loaded both fittings and taps with a shitload of jb weld and liquid gasket, but it still continues to leak. the turbo is brand new, so it cant be that leaking. anyone have any ideas on what to do?</TD></TR></TABLE>
what type of line are you using for return line? is it oil resistant blue/red type? and what type of fittings are you using, are they barbed fittings?
Old May 21, 2005 | 09:55 AM
abmerop18's Avatar
Default Re: Oil Return line is leaking (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
what type of line are you using for return line? is it oil resistant blue/red type? and what type of fittings are you using, are they barbed fittings?</TD></TR></TABLE>
i bought the oil line kit from cheapoillines.com
what is this rtv stuff you said to use?
Old May 22, 2005 | 11:55 AM
abmerop18's Avatar
anyone???
Old May 22, 2005 | 12:02 PM
Pnoyej6's Avatar
* B A N N E D *
the rtv is honda flange sealant. That is where you made your mistake you bought a cheap oil no name brand. It is a tube you can buy at the honda or acura dealer it says rtv flange sealant.
Old May 22, 2005 | 12:50 PM
stealthmode62's Avatar
Default Re: Oil Return line is leaking (pnoytegn707)
Is it leaking from the barb fitting threads (to drain flange or pan) or is it a hose to barb problem?
Old May 22, 2005 | 09:23 PM
98 blacksh's Avatar
Default Re: Oil Return line is leaking (stealthmode62)
i have the same problem hose to barb at the oil pan
Old May 22, 2005 | 10:19 PM
Default Re: Oil Return line is leaking (98 blacksh)
Hose to barb should be fixed easily with tightening the clamp. Take it off of the barb it's leaking at to clean everything really good, maybe use a new clamp, and wrench on that bitch. lol.
ericschimmel
Jul 25, 2007 03:13 PM
themorphious
Jun 11, 2006 09:18 PM
skiwithcars
Aug 9, 2005 07:52 AM
phreakmang
Mar 14, 2004 11:34 AM
Kutsuju_SLeePER
May 19, 2003 08:01 PM
