highest hp non-vtec??
Old May 24, 2005 | 07:58 AM
sunny20's Avatar
Default highest hp non-vtec??
for b18 or b20 what's the most hp you've seen w/ what parts???
Old May 24, 2005 | 10:19 AM
adseguy's Avatar
Default Re: highest hp non-vtec?? (sunny20)
on stock head like 450 I think.
You do realize that aside from compression the only difference is the cam, right?
You can get cams that are even bigger the a VTEC cam so basically you can see anywhere in the 700-800whp range just like a VTEC head. Of course the head must be ported and polished and able to rev to 10grand, but you get my point. No VTEC needed if you have big cams
Old May 24, 2005 | 10:53 AM
DragSource's Avatar
I seriously wouldn't take an LS motor to 10,000 no matter what valvetrain is in it.
The ball/socket style rocker arms are a big difference in the 2 heads.
Also, I don't think you would see power to 10,000 on many LS heads, even with substantial porting.
But yes, you can still make BIG power with a straight LS, so long as you work over the head propoerly. As an added bonus, you'll make more torque than your average VTEC setup as well thanks to a longer stroke.
But it's that same stroke that will force you to make your power a little lower than the vtec crowd.
Shoot for a 4.7-8k powerband on the LS, and you'll save yourself some heartache.
Old May 24, 2005 | 11:20 AM
95GSRTT
Guest
Posts: n/a
Default Re: highest hp non-vtec?? (adseguy)
did you just say that the only difference between a vtec head and LS head was the cams? If so i REALLY hope you are joking
Old May 24, 2005 | 11:47 AM
DragSource's Avatar
95GSRTT is correct - there are many differences.
Rocker assy. is different.
The head design itself is different
The LS head is much more restricted.
Old May 24, 2005 | 12:30 PM
hondaguyef's Avatar
Default Re: highest hp non-vtec?? (95GSRTT)
Click Here. That is a link to some pretty big numbers made by JG back in the day. I miss my LS, the torque made for an enjoyable ride
Phil
Old May 24, 2005 | 02:09 PM
sunny20's Avatar
Default Re: highest hp non-vtec?? (hondaguyef)
cool deal... thanks for the info!!!!
Old May 24, 2005 | 04:01 PM
adseguy's Avatar
Default Re: (DragSource)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT &raquo;</TD></TR><TR><TD CLASS="quote">did you just say that the only difference between a vtec head and LS head was the cams? If so i REALLY hope you are joking</TD></TR></TABLE>
I know there are more differences, but I was just generalizing since he was kindof a newbie. GJ pointing it out though
93' smurf integra
Aug 20, 2007 06:26 PM
fergs96integra
Nov 10, 2006 09:30 AM
KingOfQB
Feb 3, 2005 09:25 PM
sappsycho
Jul 31, 2002 09:16 PM
ActiveAero
Apr 8, 2002 08:31 PM
