Need help tracking down an oil feed fitting.
Old May 22, 2005 | 12:17 PM
Loco Honkey's Avatar
Default Need help tracking down an oil feed fitting.
I'm installing a Garrett GT25R, and need a banjo fitting for the oil feed where it threads into the center section. The nipple that was provided is too long, and I can't run a straight line to it because the manifold is in the way. The thread is 7/16-24. I found that a banjo from a Fox body Mustang front brake caliper fits, but I'd rather use the "right" fitting if it can be found.
Thanks for the help!
Old May 22, 2005 | 12:49 PM
stealthmode62's Avatar
Default Re: Need help tracking down an oil feed fitting. (Loco Honkey)
I have some 7/16 24 straight fittings if you need one. I know you said that you need a banjo, which I could special order, but if you decide you want a straight fitting let me know.
Flamenco T probably has the banjo you're looking for on hand.
Old May 22, 2005 | 04:01 PM
I already have the straight fitting... no way to get the line to it with the manifold in the way. How much would the special order banjo be?
$MIKE$
Feb 3, 2014 01:54 PM
torqueless
Dec 8, 2005 09:04 AM
alfee
Oct 13, 2003 04:37 PM
integra-modder
May 12, 2003 02:40 AM
reXem
Jul 8, 2002 06:31 AM
