compression results and plug question
Old May 20, 2005 | 08:41 AM
mrx's Avatar
mrx
Default compression results and plug question
Hi,
i did a compression thest, just because i was curious ;-)
#1 160psi
#2 172psi
#3 150psi (140psi in the first attemp)
#4 160psi
the engine was not fully warmed (aprox. 10min running at idle) up so i guess the piston rings will seal a bit better when totaly warm...
what do you think about #3 is it a bit low? its within specification but it is less then the others... something to worry about?
Compression Ratio is 10,2:1 on a B16A1 Engine, Stock internals.
when i pulled the plugs i saw that #2 was hell rich (totaly black, but not oily or something), the others looks normal brown, as they have to look like when idleing at 13:1-13.5:1 AFR but why is #2 so rich?
i installed DSMs, is it possible that the injector of #2 is a bit bigger (no other size, just so that more fuel comes thru it)?
Thanks
Malte.
Old May 20, 2005 | 08:44 AM
J337_UNIT's Avatar
Default Re: compression results and plug question (mrx)
for a 10.2:1 CR motor, those numbers are very low. Try adding oil into the spark plug holes ... just a little bit.. if the numbers go up, then you know that the piston ring seals are shot
Old May 20, 2005 | 08:48 AM
ginoboy1978's Avatar
Default Re: compression results and plug question (J337_UNIT)
^^^ too low, should be 190-210 range.
Old May 20, 2005 | 08:50 AM
mrx's Avatar
mrx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">for a 10.2:1 CR motor, those numbers are very low. Try adding oil into the spark plug holes ... just a little bit.. if the numbers go up, then you know that the piston ring seals are shot</TD></TR></TABLE>
Why are they low? the honda manual says something from 185-135psi is within the normal specification.
i will make a test with a fully warmed engine on sunday and if the numbers are equal i will try some oil...
Any idea with the spark plug?
Thanks
Old May 20, 2005 | 09:21 AM
s2kdre's Avatar
i have 9:5 and i had 185 in all four
Old May 20, 2005 | 09:23 AM
mrx's Avatar
mrx
Default Re: compression results and plug question (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">i have 9:5 and i had 185 in all four</TD></TR></TABLE>
you mean 9:1 or 9,5:1 ?!
if you have build a block, i swear you have brand new piston rings etc... honed the sleeves etc...
my block has 160.000km with first stock pistons... i think you have to remember this or am i wrong?
but when everybody say that i have to have more i will do the test on sunday and see what it brings.
95greenlude
Nov 3, 2007 04:21 PM
blucrx
Sep 1, 2006 07:32 AM
NegativeXero
11
Aug 18, 2006 06:52 PM
DXR
Aug 11, 2004 06:44 AM
311
Dec 14, 2002 12:18 PM
