Where to connect MAP sensor vacuum line???
Old May 23, 2005 | 07:55 AM
fast93accord's Avatar
Default Where to connect MAP sensor vacuum line???
Well, the stock map sensor on my car had its vacuum port coming off a nipple on the throttle body. I noticed that particlar vacuum port only has a hairpin hole in it,
compared to the normal vacuum ports. My question is this. I'm running a GM 3 bar map sensor now. Where should i connect the vacuum/boost line to on my intake manifold? Should i use the vacuum port with the hairpin hole in it (like stock)? Or should i use a normal full flow vacuum port???
Thanks
Old May 23, 2005 | 09:16 AM
turbo*s2k's Avatar
Default Re: Where to connect MAP sensor vacuum line??? (fast93accord)
You should be fine using either..., but I would probably use one of larger ports coming from your intake manifold.
Old May 23, 2005 | 09:31 AM
AccidentproWn's Avatar
i connected mine to the port where i unplugged my PCV valve
tony_2018
May 25, 2014 06:48 PM
tempsohc
Jun 19, 2011 06:06 PM
stackedhouse
11
Apr 25, 2011 01:26 AM
Topdawgg
Jun 25, 2007 10:02 AM
94cxhybrid-T
Sep 11, 2002 10:17 PM
