Boost problem - Wastegate or Controller?
Old May 23, 2005 | 04:20 AM
94lsboost's Avatar
Default Boost problem - Wastegate or Controller?
My wastegate is a tial 38 mm w/ .6 bar spring and my controller is a greddy profec B spec 2.
I have been running .9 bar for quite a while now and last weekend on the dyno we decided to go up to 1.1 bar. The high boost settings on my profec B were in the 60% range I believe and gain at 10. We started cranking up the % ... and eventually the gain and all we can get it to do is spike to like 1.1 or 1.2 bar (12 gain I assume is doing this), then it falls back to .9 bar.
The best I can figure, the wastegate spring is probably weak, any other thoughts?
Old May 24, 2005 | 01:06 PM
EKhothatch's Avatar
Default Re: Boost problem - Wastegate or Controller? (94lsboost)
Turn the gain up.
Old May 30, 2005 | 09:35 AM
M.A.R.C.'s Avatar
i had the same problem. set the start boost to whatever boost level u want to run. it's under set gain on the ebc... i think u press select twice to get to it. so say u wanna run 1bar... u set the "set gain" aka start boost to 1bar. then u adjust the % until it holds that level. i have my gain @ 10%. hope this helps
94lsboost
Jan 6, 2005 05:58 PM
99gsr-t
Sep 7, 2004 08:14 PM
9krpm
Mar 11, 2003 06:54 PM
DIRep972
Aug 18, 2001 03:34 AM
