Coolan Overflow issue
Old Apr 5, 2010 | 11:32 AM
crcale's Avatar
Default Coolan Overflow issue
Ok. I have a 1993 honda civic. d16z6 fully built...
1mm over valves
full port and polish head
wiseco pistons
eagle rods
block gaurd
Gt35r 8-10psi
Coolant overflow filling but not returning into radiator causing air pocket...
im only running 8-10 psi....
compression test, coolant pressure test (for 1hr at 20 psi) no leak, cylinder leakdown test.... everything passes..
Replaced head gasket, gutted the center of thermostat, changed all my coolant lines, new radiator, new radiator fan, Alllmmoossttt everything has been replaced.. I cant figure out the issue .. alllso the head studs were replaced and retorqued after 5 full cycles heating up cooling completly off...
Any input would be greatly appriciated...
Old Apr 5, 2010 | 11:43 AM
YARO.'s Avatar
Default Re: Coolan Overflow issue
radiator cap? Have you been bleeding the system every time you flush it? is the coolant resirvore in the stock location? Is it over heating?
Old Apr 5, 2010 | 11:50 AM
crcale's Avatar
Temp fluctuates while driving..
Yes i have burped the coolant..
If i pore the overflow back in its fine.. Fills back up... pore it back in and its fine again... idk.. No loss power or anything... idk what it could be... Resivoir in stock location YES.
It gets air in the system because coolant goes into the overflow resivoir!.. but will not circualte back into the radiator CAUSING AIR POCKET!
Old Apr 5, 2010 | 02:06 PM
importdude2000's Avatar
why is it filling up is #1
im guessing head lift issues
Old Apr 5, 2010 | 02:22 PM
welfarepc's Avatar
sounds like you are using chinese head gaskets or your head/deck is not flush
Old Apr 5, 2010 | 03:31 PM
crcale's Avatar
idk on only 9psi how is head lifting on brand new studs anddd cylinder leaakk down test passed also compression test 200 on 1 2 3 4 im kinda stumped
Old Apr 5, 2010 | 04:18 PM
rat city rex's Avatar
Originally Posted by crcale
idk how is head lifting on brand new studs
Here's your sign...
Old Apr 5, 2010 | 04:27 PM
DeLucia's Avatar
lifting the head
Old Apr 5, 2010 | 06:25 PM
ctr32's Avatar
new head gasket, get head decked!
Old Apr 5, 2010 | 06:31 PM
LastGenEK's Avatar
Originally Posted by ctr32
get head decked!
To do this dont you have to pull The engine apart?
Old Apr 5, 2010 | 09:29 PM
Nope you have to pull the gas tank. lol
Old Apr 6, 2010 | 01:59 PM
crcale's Avatar
head is off to the head shop.. tired of guessinggg... idk why but i guess sohc are head lift prone... im getttinngg the head checked for true, and cleaned and also haveing it resurfaced... head gasket is ordered and it should be back together over the weekend.. ugggg stressfulllll
Old Apr 6, 2010 | 02:36 PM
welfarepc's Avatar
not at all.
what brand head gaskets are you using?
i would only use a gasket that is made in japan. just my personal preference from trial and error.
also what are you doing when you are installing them? any sprays, etc? proper tq sequence? dowels are in there? what torque and steps are you going by?
was the block decked?
was the head decked?
detonation?!?!?
Old Apr 10, 2010 | 10:15 AM
crcale's Avatar
Fixed!!!
Head was .006 warped...
It was missing the 2 dowels.
Cometic headgaskets wouldnt allow for the dowels but now i have a factory head gasket..
Thanks for the input.
mattthethug
Aug 31, 2010 04:03 PM
dylokjai
10
Jul 11, 2008 03:33 PM
soulo
Jun 8, 2008 10:28 AM
94turbosi
May 26, 2006 03:03 AM
blackexvtec
Jan 31, 2006 09:43 PM
