Overheating
Old Apr 20, 2010 | 09:12 PM
victoriasamantha's Avatar
Icon2 Overheating
My friend has a turbo gsr in a civic. He can drive the car all day and it wont overheat. But after going under boost a couple of times the car will overheat when he stops. Once he gets moving the temp will go back to normal but if he stops again it will overheat even with normal driving until he lets it cool off for a while. The fan does work and he removed the center section of the thermostat.
thanks
Old Apr 20, 2010 | 09:22 PM
Terrible One's Avatar
Default Re: Overheating
sounds like a blown head gasket.
Old Apr 21, 2010 | 04:47 AM
DrivinVtec's Avatar
I have a similar issue. A compression check would also tell you if the head gasket was okay...correct?
I did put a shroud on my fan and it helped big time. I was going to make a heat shield and see if that would help.
Old Apr 21, 2010 | 08:23 AM
He has arp head studs. Do you have to retorque them after driving the car for a while or is the one time good?
thanks
Old Apr 21, 2010 | 08:27 AM
lsef's Avatar
water pump?
Old Apr 21, 2010 | 08:45 AM
boostin99em1's Avatar
no you dnt have to retorque headstuds and does sound like a waterpump
Old Apr 21, 2010 | 09:15 AM
how can you test the water pump. also he put a new one on 2 years ago and barely drives the car. There is no fluid on the ground under the car.
Old Apr 21, 2010 | 09:34 AM
b20beast83's Avatar
bump to find info
Old Apr 21, 2010 | 09:44 AM
sanman000719's Avatar
how close is the down pipe the the radiator heat soak can also cause this or high temps under the hood as well
Old Apr 21, 2010 | 11:41 AM
th3pwn3r's Avatar
Can we get pictures? A good shroud may be in order.
Old Apr 21, 2010 | 01:41 PM
DrivinVtec's Avatar
hummmm.. this could be why im running a bit warmer.
Old Apr 21, 2010 | 02:01 PM
i had these issues as well so instead of changing anything up I just went to e85 lol never ever gets to 190 degress at the track
Old Apr 21, 2010 | 06:36 PM
the down pipe is close to the radiator so he wrapped the downpipe and manifold with heat wrap. the dump tube gets close to the radiator also so he is going to heat wrap that also. Also he just got drag radials so he gets more traction than before and not just spinning thu the gears. This should create more heat in the engine bay.
Old Apr 22, 2010 | 11:45 AM
also someone told me if the car is running lean it could overheat. if so at what point would on a a/f gauge would be too lean for a turbo car?
thanks
Old Apr 22, 2010 | 12:02 PM
Glock17's Avatar
Yeah if the car is running lean it would cause the motor to run hotter. Which can cause the motor to overheat. I would suggest getting a wideband, to see where the A/F ratio at, it should be around 11-12.
Old Apr 22, 2010 | 12:08 PM
i know for part of the time it gets to 12.2 sometimes but the place where it was tuned said 12.2 is the highest you want it to go. he has a wideband but I need to ride with him to watch it
Old Apr 22, 2010 | 12:13 PM
Glock17's Avatar
Make sure you check the radiator cap, I had a similar problem a while back. I ended up changing the thermostat, waterpump, and headgasket. It ended up being the radiator cap, wasted a lot of time, because I didn't check the little things first. I would pressure test the coolant system and do a leak down test.
Old Apr 22, 2010 | 02:03 PM
DrivinVtec's Avatar
this is what I did today trying to lower temps.
before:
after:
seems to help. it didnt get as hot as it usually does. still a bit warm but i think i just need another fan. I just have 1 pusher.
Old Apr 22, 2010 | 02:08 PM
here is mine you see the down pipe is actually hitting the radiator ima need me some heat wrap also
Old Apr 22, 2010 | 02:12 PM
DrivinVtec's Avatar
is your oil source tapped off the head?
Old Apr 22, 2010 | 02:15 PM
off the vetec solinoid
Old Apr 22, 2010 | 02:24 PM
DrivinVtec's Avatar
gotcha..
Old Apr 22, 2010 | 02:26 PM
lost my headlight for the top mount though lol
Old Apr 22, 2010 | 02:54 PM
DrivinVtec's Avatar
just a track car i guess.
Old Apr 22, 2010 | 02:55 PM
it wasnt lol might be now
