Spark Plug question
Old Apr 19, 2010 | 12:19 PM
Hand_Fed's Avatar
Default Spark Plug question
So I've noticed that pt# 3330 for NGK plugs have changed. Lately I've been using pt# 6282. Now, since my car is turbocharged which plugs would be best to keep running on?
Old Apr 19, 2010 | 02:50 PM
BoostedBlueF22's Avatar
Default Re: Spark Plug question
Copper plugs are great for boost!!!! Just make sure you keep your gap tighter then factory specs.
Old Apr 19, 2010 | 02:54 PM
TEAM ASSASSIN SI's Avatar
i use 9's ngk's
Old Apr 19, 2010 | 09:33 PM
Hand_Fed's Avatar
I have mines gapped at 25. Wha'ts factory specs again?
Originally Posted by TEAM ASSASSIN SI
i use 9's ngk's
What does that mean?
Old Apr 20, 2010 | 05:00 AM
danp1uk's Avatar
he means the iridium NGK, the 9 means the heat rating, which in this case is very high
Old Apr 20, 2010 | 05:08 AM
EJ1_Ex's Avatar
I ran NGK bkr7e's in my old turbo sohc and never had a problem. Gapped them to like .20
Old Apr 20, 2010 | 05:13 AM
dpetro1's Avatar
how much power are you making? the 6282 (bcpr7es) are just fine. also the 4644 (bkr7e) is pretty much the same plug and works well.
Old Apr 20, 2010 | 03:40 PM
jdmturboitr's Avatar
Yea I use the 4644 gaped at .20-.22......runs fine....
Old Apr 21, 2010 | 07:22 PM
Hand_Fed's Avatar
Thanks guys. I will do that.
B16EJ
Apr 6, 2014 06:52 PM
91akira
Mar 12, 2010 08:23 AM
vltnolia
Nov 15, 2005 01:40 PM
patdemps
Sep 10, 2003 11:33 AM
Flux
Jul 29, 2002 09:46 AM
