What causes a PISTON Ring to Break?
Old Apr 19, 2010 | 06:50 AM
b20beast83's Avatar
Default What causes a PISTON Ring to Break?
So my Built B16a Engine [Srp STD Size Pistons] began to missfire[Subaru sound]
Pulled Head, Valves good.
So i took out the piston in the cylinder with low compression.
So turned out i had a BROKEN TOP Compression Ring.
What could cause it to break?
I went from 4th gear at 8200rpm, Missing 5Th gear, into 3Rd gear
So
4th Gear 8200rpm -> 3Rd Gear XX000RPM.
Any insight would be useful
Old Apr 19, 2010 | 07:17 AM
90blackcrx's Avatar
Default Re: What causes a PISTON Ring to Break?
Was it just the ring, or was the ring land also cracked ?
Old Apr 19, 2010 | 12:39 PM
Captain Bondo's Avatar
Hard to imagine a ring failing without killing a land as well... might have had ring flutter I guess...
Old Apr 20, 2010 | 07:55 AM
b20beast83's Avatar
whats ring flutter?
ringlands are perfect.
no one can give me a clear indication why the ring failed ;(
Old Apr 20, 2010 | 09:35 AM
jdm602's Avatar
flutter is oscillation of the ring. usually detonation cracks ring lands or rings themselves. but flutter can too. along with improper end gaps or placement.
i would say it failed cause you did a 4-3 shift, overrevved it and it made one of the rings flutter.
Old Apr 20, 2010 | 09:43 AM
JDogg's Avatar
ring gap too tight? what do the cylinder walls look like
Old Apr 20, 2010 | 09:45 AM
blaze the chemi's Avatar
Interested in which pistons you ran, compression wise, and what power you were putting down. I have SRP's in my B16a, 9.9:1 with the provided rings too.
Do you have different rings other than the JE/SRP?
Old Apr 20, 2010 | 04:45 PM
b20beast83's Avatar
Im not 100% certain of the compression of the pistons
I got them used.
I think there around 8:1 Cr. [-std size pistons]
My Compression was about 140-150psi across the board.
Except for #3, which was 80.
I made 246whp @12psi With a B16a, Type R cams, conservative timing and street tuned.
Garrett 60Trim / .63 Backend.
2.5"Dp and Exhaust.
I have 20 thou over je piston rings.
Im gonna file it down and just change top compression ring and go again.
I took them all out, and all look perfect, just the way i bought them used.
I think they hold up to the abuse.
Im going to shoot for 20-24psi or 400whp or closest / pump gas, 91oct.
I am using JE Rings.
Honestly, i dont really feel the lower compression out of boost.
It is almost not noticeable.
Hope this helps you out.
Old Apr 20, 2010 | 04:46 PM
b20beast83's Avatar
Cylinders are perfect.
Old Apr 20, 2010 | 11:48 PM
make sure the 2nd ring gap is larger than the 1st ring gap. Gap em on the loose side.
#1rudebwoy
Oct 5, 2010 09:33 AM
RACEPAK
Aug 30, 2008 09:59 PM
Muckman
Nov 11, 2005 02:48 PM
ericrx_88
Jun 1, 2005 11:34 PM
Eddoes
May 21, 2004 02:04 PM
