Just installed my JG manifold HELP!
just intstalled my intake manifold and ran into a problem.
i could start the car and it would rev up to 3-4k and stay and sputter.
need help ASAP!
need help ASAP!
HELLO,GOOD MORNIN'
Re: Just installed my JG manifold HELP!
you have a vaccum leak. But i think your IAT and IACV is switched. Then if it's still acting up you probably burned the IAT cause the 5v sensore cant take 12v which is what the IACV takes. Look at the IAT and see if the tip is burned
ok. so if its a vaccum leak itll just rev up to 3.5k and stay?
ok.. get carb cleaner and spray it around the intake manifold gasket. if ur engine start to die out then u found the leak. i'm surpised no one's suggested this earlier. it's the first thing u do when u suspect a vaccuum leak. it's possible you didn't torque the gasket down properly.
might not be the "gay" blox intake manifold gasket. its a real bitch to clean off all of the old gasket so if a little of the old gasket material was missed it can cause the new gasket to leak. just a thought.
yup, especially if the new gasket is one of those plastic ones. they're not the best at sealing and are thick so you'd want to get longer studs to bolt it down better.
hook up an air compressor the the inlet of your turbo, then give it some air,
when you start to hear the leak, youl find it,
if you dont hear anything,
prolly switched the IACV and the Purge plug
CountDracura
03-24-2009 12:56 PM
