Turbo build started, couple questions
I just purchased an HF manifold and will be running it with a used Nissan t25. I have access to e85 stations and plan on using it. For a goal of around 220whp tops, what size injectors should I plan on using. 550's?
Also, are there any injectors that size that will plug right into the stock '96 harness?
Man U FTW
Re: Turbo build started, couple questions
For 220whp or so on E85, you would calculate as follows...
220whp x 6cc(per whp) = 1320 cc total flow
1320cc total x 1.3 E85 conversion = 1716 cc E85
1716 cc / 4 inj = ~430cc per injector
That equation above will give you a rough estimate of injector sizing for a Honda at base fuel pressure. Having said that, a set of 550s would do just fine with your setup
Thanks. Now, short of purchasing some RC injectors, are there any that I can use that will plug right in? Do I need to look for high or low impedance injectors?
