MSD to OEM
Old Apr 25, 2010 | 07:56 PM
Dubs13's Avatar
Default MSD to OEM
I'm currently running an MSD distributor with external coil. I'm pretty sure the rotor is loose or something on it cause I get random sputtering while driving sometimes and the dizzy is also just loud and rattles on cold startups. Here are my two questions:
1) Is it likely that the rotor be the problem or would it be the coil or the bearing itself?
2) Could I simply remove the MSD cap, rotor, and coil and just replace them with a stock OEM cap and rotor with internal coil? Would this mess with my tune at all?
Old Apr 25, 2010 | 08:04 PM
TheShodan's Avatar
Moderator
Default Re: MSD to OEM
1) could be the rotor, could also be the plugs. It's always best to replace them together. If it were the coil, in many cases, the car wouldn't start at all.
2) Yes, but you would need to replace rotor (OEM is fine) but not the coil or the cap. Chances are the rotor alone is fine to replace.
Old Apr 25, 2010 | 08:40 PM
Dubs13's Avatar
I changed the plugs recently and it didn't change anything. Could a bad rotor account for power loss?
Old Apr 26, 2010 | 02:05 AM
cleansi's Avatar
i had the same problem on my em1. no matter what i changed it still sputtered with the msd module, my tuner told me to ditch it and put it back to oem. runs great now looks better too, it was really a waste of money for me. most cars dont really need it.
just my 2cents.
Old Apr 26, 2010 | 06:16 AM
TheShodan's Avatar
Moderator
Though I like the MSD module myself (well, at least an aftermarket ignition system), cleansi has a point if the module itself may be bad. Try replugging back to stock and see what happens. If the module is bad, it could cause a lot what you're experience
Old Apr 26, 2010 | 02:24 PM
Dubs13's Avatar
By "replugging" it back to stock you mean putting an oem distributor on? Should I change the whole distributor or just the cap, rotor, and coil? Cause I assume the base must be the same for both the MSD and OEM, no?
1sikhatch
Apr 26, 2010 02:35 PM
hondatech94
Apr 6, 2007 06:59 AM
redDAinteg
Jun 12, 2005 11:57 AM
jazz215
19
Aug 17, 2003 10:25 PM
stegs
Jul 24, 2002 03:24 PM
